fluidistic
- 128
I'm rusty with fortran and programming in general. I can't see my "error" in a code that I wrote from scratch.
Basically I wanted to get some fun and solve for a temperature in thermodynamics where I must get "T_f" which appear in a transcendental equation: ##A\ln \left ( \frac{T_f^2}{T_1T_2} \right )+2B[2T_f-(T_1T_2)]=0##.
Where T_1 is worth 100, T_2 is worth 200, A=2 and B=0.005.
Here is my code:
that I compile along with
The problem is that for the values I said above, I get the message "There's an even number of root(s) in that interval". Thus apparently the condition f(a)*f(b)>0 is satisfied. However when I enter the numbers in my pocket calculator I get f(a)=-2.3862... and f(b)=2.3862... where I truncated both values. Thus the condition is not satisfied.
I really don't see what's wrong. Any idea?
Edit: I tried with many different values for a and b. I even changed t_1 and t_2, same message.
Edit2: I've just tested the values of fa and fb. It thinks they are worth infinity. Going to check this out.
Edit3: No idea why it thinks they are worth infinity. o_0.
Edit4: ok it does not plug in t_1 and t_2 inside my function.
Here is my code:
Code:
program rootfinderbisection
implicit none
real(4)::a,b,xn,fa,fb,fn,f,e,x_n,t_1,t_2
write(*,*)"Enter the temperatures t_1 and t_2"
read(*,*)t_1, t_2
write(*,*)"Enter your interval guess, [a,b]"
read(*,*)a,b
write(*,*)"Enter the precision you want"
read(*,*)e
fa=f(a)
fb=f(b)
if (abs(fa)<e) then
write(*,*) "The solution is",a
stop
else if (abs(fb)<e) then
write(*,*)"The solution is",b
stop
end if
if (f(a)*f(b)>0) then
write(*,*)"There's an even number of root(s) in that interval"
stop
endif
xn=0.5*(a+b)
fn=f(xn)
do while (abs(fn)>e)
if (fa*fn<0) then
b=xn
fb=fn
else
a=xn
fa=fn
endif
xn=0.5*(a+b)
fn=f(xn)
end do
write(*,*)"The solution is",x_n
end program
Code:
function f(x)
implicit none
real(4)::f,x, t_1,t_2
f=2.*log((x**2.)/(t_1*t_2))+2.*0.005*(2.*x-(t_1+t_2))
end function
