Fortran code problem
  • Fortran
  • Thread starter just physics
Main Question or Discussion Point
we have to write a code to solve system of equations by writing them in matricies (tridiagonal matrix) form .....
the first step is to enter the coefficients of the variables (r1,r2,r3,...) and then the answers to the equations (b1,b2,b3,...) by using array , and print the equations in the form:
r1X1+r2X2=b1
r1X1+r2X2+r3X3=b2
i made the code and i get the answers but i have to insert a code to check the answers that i get i.e: if x1=1 ,x2=6 ,r1=1,r2=2,b1=13
then the program print
1*1+2*6=13
i cant make this step can any1 help me please :(
Answers and Replies
4,852
r1X1+r2X2=b1
r1X1+r2X2+r3X3=b2
1*1+2*6=13
Here is the code...
Code:
program final_project
implicit none
!Solve the code in the general case for n equations
! and allow the user to enter the values of B(i) for AX=B
real,dimension(:,:),allocatable::system
real,dimension(:,:),allocatable::m,lower,upper,c,x
real,dimension(:),allocatable::b,y,solution
real::sum
integer::i,j,n,k,p,h
print*," this program is used to solve tridiagonal matrix with 7 unknowns"
print*,"enter the dimension of the matrix == # of equations u want to solve"
read*,n
allocate(system(n,2*n))
allocate (m(n,n))
allocate(lower(n,n))
allocate(upper(n,n))
allocate(c(n,n))
allocate(x(n,n))
allocate (b(n))
allocate(y(n))
allocate(solution(n))
!! now to print the matrix before the factorization :
do i=1,n
 do  j=1,2*n
	  system(i,j)=0
     if(j<=n.and.(i>j.or.i<j)) system(i,j)=0
      if(j<=n.and.i==j) system(i,j)=1
      if (j>n .and. (j==n+i+1 .or. j==n+i-1)) system(i,j)=1
	  if (j==n+i) system(i,j)= 2
 end do
 end do
 print*,"the matrix befor the factorization is"
 do i=1,n
 write(*,'(1x,20f6.1)') system(i,:)
 end do
print*,"____________________________________________________________"
! now we want to enter the elements of matrix (B) where AX=B
print*,"please enter the values of the matrix B :"
   do i=1,n
     read*,b(i)
    end do
print*," THE EQUATIONS U WANT TO SOLVE WILL BE :"                !inner loop writes one coefficient and variable at a time, without carriage return
 do i = 1, n													 !inner loop writes left-hand-side of equal sign
   do j = 1, n													 !'sp' format spec indicates to explicitly show the positive or negative sign of the r coefficient
     write(*,"(sp,f5.1,'X',ss,i1)", advance='no') system(i,j), j !'ss' format spec turns off the previous 'sp'
   end do
   write(*,"(' = ' , f5.2)") b(i)
 end do
! now we want to start the factorization :
do p=1,2*n
do i=p+1,n
    m(i,p+n)=system(i,p+n)/system(p,p+n)
      do j=p,2*n
         if(j>n)     system(i,j)=system(i,j)-m(i,p+n)*system(p,j)
         if(j<=n)     system(i,j)=system(i,j)+m(i,p+n)*system(p,j)
      end do
end do
end do
print*,"the matrix after the factorization is"
		do i=1,n
		end do
 print*,"_________________________________________________"
 ! now want to find the lower matrix of factorization :
do i=1,n
do j=1,n
  lower(i,j)=system(i,j)
end do
end do
print*,"The Lower Matrix Of The Factorization Is"
	do i=1,n
	   write(*,'(5x,20f9.4)') lower(i,:)
	end do
print*,"_____________________________________________________"
! want to find the upper matrix:
do i=1,n
do j=1,n
   upper(i,j)=system(i,j+n)
end do
end do
print*," the upper Matrix of Factorization :"
do i=1,n
     write(*,'(5x,20f9.4)') upper(i,:)
end do
print*,"________________________________________________________"
!!!! now using the lower matrix we will get the matrix y :[[ LY=B ]]
 y(1)=b(1)/lower(1,1)
 do k=2,n
   sum=0
	 do h=1,k-1
	    sum=sum+lower(k,h)*y(h)				      !! forward substitution
	 end do
	   y(k)=(b(k)-sum)/lower(k,k)
end do
print*,"__________________________________________________________"
!! now using the upper matrix we will get the solutions for x : [[UX=Y]]
 solution(n)=y(n)/upper(n,n)
do k=n-1,1,-1
  sum=0
 do h=k+1,n
	sum=sum+upper(k,h)*solution(h)		    	!! back substitution
 end do
	    solution(k)=(y(k)-sum)/upper(k,k)
end do
print*," the values of X1,X2,...,Xn , THAT SATISFY THE EQUATIONS WILL BE :"
print*,""
do i=1,n
	print*,solution(i)
end do
print*," to check the answers :"
!!! what im gonna do here ???!!!
end program final_project
53
You can use the same nested do-loops that I gave you before...the one under your
print*, " THE EQUATIONS U WANT TO SOLVE WILL BE : "
but instead of printing literal 'X' followed by 'j' number, you need to print the value of such Xj (is it in solution(j) ?)
You need to slightly modify just one line, the one in the inner loop....I won't do it for you, this time.
Related Threads for: Fortran code problem
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
