Fortran coding do loop
  1. Sep 5, 2011 #1
    Can some1 kindly help me understand the following code, I am trying to translate the following code in VBA:
    Thanks in advance
    FFLC = FLC .......i understand this part
    ANGLE=PI/6 !Suppose 30 Degrees .......i understand this part
    Do 21800 I=i,5 .......Don't understand this
    FLC=FFLC-COS(ANGLE)*NDIA
    FLE=SQRT(FLB*FLB+FLC*FLC) .......i understand this part
    21800 ANGLE=ATAN2(FLC,FLB).......i understand this part
    if (R.NE.o.)D=R/2.+NDIA/2.......i understand this part
    FLCUT = ........ .......i understand this part
    LE=IFIX(FLE).......Don't understand this
    My answer for FLCUT is 2387 when using the 30 degree angle but fortran result 2397 (after using the iteration which I dont understand)
    Can someone please help me understand this please?
    Regards
  3. Sep 5, 2011 #2
    Do 21800 I=i,5 .......Don't understand this --> execute lines until line number 21800, from I=i to I=5 ; that is 5-i+1 iterations
    LE=IFIX(FLE).......Don't understand this-->IFIX must be some function / subroutine otherwise it would be taking dimension of a Real
  4. Sep 5, 2011 #3
    thanks mate,
    in above equation, I understand that the iteration required to refine the angle. it is starting with 30 degrees angle and iterating it (which I dont understand how).... could you provide me a break down of iteration. I am totally new with fortran. I'll appreciate if you could take me through the step by step and tell me what would be the angle after iterating the equation.
    Thanks
  5. Sep 5, 2011 #4
    Hi :)
    You are welcome.
    Can you post the whole program code
    PROGRAM xxxx
    STOP
    END.
    The dots.
  6. Sep 5, 2011 #5
    Fflc=flc
    angle=pi/6 !suppose 30 degrees
    do 21800 i=1,5
    flc=fflc-cos(angle)*ndia
    fle=sqrt(flb*flb+flc*flc)
    21800 angle =atan2(flc,flb)
    if(r.ne.0) d=r/2+ndia/2
    flcut=fla+fle-2*(d+ndia/2)*tan(angle/2)+d*angle
    le=ifix(fle)
    return
    where fla = 1865
    flb = 145
    flc540
    r=80
    ndia=16
    fle should have been 555 (after iteration) but when i ran it with 30 degree my answer was 545.
    I am just wondering how should fle be 555 after.
    Pls help
  7. Sep 5, 2011 #6
    Fflc=flc
    do 21800 i=1,5
    le=ifix(fle)
    return
    where fla = 1865
    flb = 145
    flc540
    r=80
    ndia=16
    Pls help
  8. Sep 5, 2011 #7
    I do not t see the entire program , maybe you should manually enter Pi/6 in radians which is appr. =
    0,523598776
  9. Sep 5, 2011 #8
    i have tried pi/6 and which results in FLE = 545 but program is resulting in 555. This diffirence is likely due to this iteration
  10. Sep 5, 2011 #9
    It also could be due to declaration mismatch, try to declare all your values Double Precision or Real and and when doing operations inside the code, use real number formats for numbers
    , eg : Pi/6=make it Pi/6.0 where Pi should be declared a REAL or D.P:
  11. Sep 5, 2011 #10
    and i am trying to understand what does Do loop is changing in entire process
  12. Sep 5, 2011 #11
    please help . . .. i dont understand this.... all of my work is waiting at this bugger
  13. Sep 5, 2011 #12
    Sir/Ma'am, Personally , I need to see the entire code. Otherwise, I am sorry I can not offer any help :(
  14. Sep 5, 2011 #13
    btw I am a female ..
    this is the entire code..... to calculate the bar length of a F shaped steel bar.....
    there are 99 other codes like these for other types of the shapes but they are similar. so somehow if we figure this code out, will mean all sorted ......
    the only place I see Do loop is changing is the angle of the bar. the program is using 30 degree angle as a starting point and than refining the angle using the iteration. And I cant really understand how exactly the do loop is refining the angle....
  15. Sep 5, 2011 #14
    Ok I'll do the first and second iterations, you do others
    flc=540-8*sqrt(3)
    flb = 145 in all iterations
    atan2(flc,flb)= atan of the angle of (540-8*sqrt(3) ) + 145 j
    angle=0.269 rads=15.43 degrees
    2nd iteration
    flc=526.1436-sqrt(3)*8
    flb=145
    atan2(512.2902 , 145)
    angle at second iteration becomes angle= 0.2758 rads =15.8 degrees
    Something like that
  16. Sep 5, 2011 #15
    BTW your gender would not matter to me but what we are dealing here is Fortran 90 Language, sorry I only can speak WF77.
    Hope you'll find help.
    Best Regards.
  17. Sep 5, 2011 #16
    thank you very for all your help......
    I am really really thankful for all your assistance......
    I am going to try this now and hope will get the right answers.....
    Once again thanks
  18. Sep 5, 2011 #17
    oh i only mentioned my gender cos you said sir/ madam..... i didn't mean any wrong.... Apology for any inconvenience
  19. Sep 5, 2011 #18
    My Apologies. I just was being ethical and stuff, I could not think I would cause any misunderstanding. I am Terribly sorry.
    Good Luck in the Forum, Lady.
  20. Sep 5, 2011 #19
    no need to apologize
    I am really very thankful for your time and everything
    Kindest regards
  21. Sep 5, 2011 #20
    This is what I get with your fortran code:
    Code (Text):
     fla =  1865.
     flb =  145.
     flc =  540.
     r   =  80.
     pi =  3.141592
     i =  1
     angle=  0.52359873
     flc =  526.1436
     fle =  545.7583
     angle=  1.3018816
     i =  2
     angle=  1.3018816
     flc =  535.749
     fle =  555.02435
     angle=  1.3064796
     i =  3
     angle=  1.3064796
     flc =  535.82
     fle =  555.09283
     angle=  1.306513
     i =  4
     angle=  1.306513
     flc =  535.8205
     fle =  555.0933
     angle=  1.3065132
     i =  5
     angle=  1.3065132
     flc =  535.8205
     fle =  555.0933
     angle=  1.3065132
     flcut =  2397.086
    I would like to point out that having 'pi' defined or not does not make that much of a difference after the first iteration...I have opted to defined it, though, since clearly it was intended to be there.
Loading...
Similar Threads for Fortran coding loop
Pipe Expansion Loop
M-code vs. P-code in GPS
