Carburization: Calculating Time w/Bisection Method
  • Comp Sci
  • Thread starter rajpintoo
  • Tags
    Method Time
In summary: Yes, that could be the issue with your computation. The given interval [A,B] is in years and you need to convert it to seconds before using it in your calculations. Similarly, the answer you get will be in seconds and you need to convert it back to years before printing it.To define a function, you need to use the keyword "FUNCTION" before the function name and specify the input and output variables. For example:REAL FUNCTION c_avg (t)USE space_dataIMPLICIT NONEREAL, INTENT(IN):: t...END FUNCTION c_avgThe "t" in parenthesis after the function name is the input variable for the function. This is the variable that will be used in the calculations within the
rajpintoo
MODULE space_data
REAL :: l !LENGTH OF THE BAR
REAL :: temp !TEMPERATURE IN KELVIN
REAL :: d_0 !CONSTANT DIFFUSION PARAMETER
REAL :: q !ACTIVATION ENERGY
REAL :: c_0 !INITIAL CONCENTRATION AT X=0
REAL :: r=8.31 !IDEAL GAS CONSTANT IN J/molK
REAL :: c_r !DESIRED END CONCENTRATION
INTEGER :: imax=30 !MAXIMUM ITERATIONS
REAL :: eps=1E-4 !MAXIUMUM ERROR
REAL :: a, b !INTERVAL OF EVALUATION [A,B]
REAL :: t
REAL :: exp, df !, erf, c, c_avg
END MODULE space_data
PROGRAM carburization
USE space_data
IMPLICIT NONE
CHARACTER :: choice
REAL :: f, root
INTEGER :: ercode
DO
WRITE(*,*) 'a) Enter new data'
WRITE(*,*) 'b) Calculate time until desired concentration'
WRITE(*,*) 'q) Quit'
WRITE(*,'(A,\)') 'Enter choice: '
READ(*,*) choice
SELECT CASE(choice)
CASE('A','a')
CALL call_data()
CASE('B','b')
CALL bisection(f, root, ercode)
CALL results()
CASE('Q','q')
STOP
END SELECT
END DO
CONTAINS
SUBROUTINE call_data()
USE space_data
IMPLICIT NONE
WRITE(*,'(A,\)') 'Enter initial end concentration (%): '
READ(*,*) c_0
WRITE(*,'(A,\)') 'Enter diffusion parameter (m^3/sec): '
READ(*,*) d_0
WRITE(*,'(A,\)') 'Enter activation energy (J): '
READ(*,*) q
WRITE(*,'(A,\)') 'Enter temperature (K): '
READ(*,*) temp
WRITE(*,'(A,\)') 'Enter length of bar (m): '
READ(*,*) l
WRITE(*,'(A,\)') 'Enter desired average final concentration (%): '
READ(*,*) c_r
WRITE(*,*) ''
WRITE(*,*) ' The bisection method needs an initial search interval [A,B].'
WRITE(*,*) ''
DO
WRITE(*,'(A,\)') 'Enter a A (Years):'
READ(*,*) a
WRITE(*,'(A,\)') 'Enter a B (Years):'
READ(*,*) b
IF(a < b) THEN
EXIT
ELSE
WRITE(*,*) 'Error- left end point needs to be smaller than right end point.'
WRITE(*,*) 'Please enter again:'
END IF
END DO
END SUBROUTINE call_data
END PROGRAM carburizationSUBROUTINE bisection(f, root, ercode)
USE space_data
IMPLICIT NONE
INTEGER::I
REAL,EXTERNAL::F
REAL,INTENT(OUT)::ROOT !THE ROOT WE ARE TRYING TO FIND
REAL::X1,X2,X3,F1,F2,F3,D,D01 !X VALUES, F(X) VALUES AND INTERVAL LENGTHS
INTEGER,INTENT(OUT)::ERCODE !ERROR CODE WILL RETURN AN INT VALUE BASED ON OUTCOME
!-1 MEANS ITERATION CNT EXCEED
!-2 MEANS NO ROOT IN INTERVAL A-B
!-3 UNKNOWN ERROR
! 0 ROOT FOUND, BISECTION METHOD SUCCESSFUL
X1=A
X3=B
F1 = F(X1)
F3 = F(X3)
IF(F1*F3>0) THEN
ERCODE = -2 !-2 MEANS NO ROOT IN INTERVAL A-B
ELSE
D=1
I=0
D01=A-B
DO
X2 = (X1+X3)/2.
F2 = F(X2)
IF(D<EPS) THEN
ROOT = X2
ERCODE = 0 !SUCCESS
EXIT
ELSE IF(I>IMAX) THEN
ERCODE = -1 !-1 MEANS ITERATION CNT EXCEED
EXIT
END IF
IF(F1*F2<0) THEN !LEFT
D = (X2-X1)/D01
F3 = F2
X3 = X2
ELSE IF(F2*F3<0)THEN!RIGHT
D = (X3-X2)/D01
F1 = F2
X1 = X2
ELSE IF(F2 == 0) THEN
ROOT = X2
ERCODE = 0 !SUCCESS
EXIT
ELSE
ERCODE = -3 !-3 UNKNOWN ERROR
EXIT
END IF
I = I+1
END DO
END IF
END SUBROUTINESUBROUTINE results()
USE space_data
IMPLICIT NONE
WRITE(*, '(T5,A)') 'RESULTS:'
WRITE(*, '(T5, 50("-"))')
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.3, 1X, "|")') 'Initial end concentration (%)',c_0
WRITE(*,'(T5, "|", 1X, A,T40, "|", ES12.3, 1X, "|")') 'Diffusion parameter (m^3/sec):',d_0
WRITE(*,'(T5, "|", 1X, A,T40, "|", ES12.3, 1X, "|")') 'Activationenergy (J):',q
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.2, 1X, "|")') 'Temperature (K):',temp
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.2, 1X, "|")') 'Length of bar (m):',l
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.3, 1X, "|")') 'Final concentration (%):',c_r
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.3, 1X, "|")') 'Computed diffusion time (days):',t
WRITE(*,*)
END SUBROUTINE results
REAL FUNCTION f()
USE space_data
IMPLICIT NONE
f = c_avg - c_r
END FUNCTION fREAL FUNCTION c ()
USE space_data
IMPLICIT NONE
REAL :: z, x
df = d_0*(exp**(-q/(r*temp)))
x=l
z = x/(2*df*t)
c = (c_0/2.)*(1 - ERF(z))
END FUNCTION cREAL FUNCTION c_avg ()
USE space_data
IMPLICIT NONE
REAL :: delta_x, idx
INTEGER :: i
delta_x = .2
DO i = 0, 5
idx = i*delta_x
c_avg = c_avg + (1/6.)*( c(idx,t) )
END DO
END FUNCTION c_avg
Can someone just error check this and explain what's wrong the compiler just tells me random errors which I don't know
Tell us what the errors are - they are probably not "random."
Hmm alriight it says that C_avg has no implicit type
Hey I think you're in my class. c_avg is a function but you defined it as just a REAL in the module. I didn't define any functions in the module because I kept getting errors. You also have to have input variables for your function's dummy variables. So c_avg would just be a function of time because we only have to calculate the concentration at the end of the bar (x = Length of bar). I don't have any compiler errors but I keep getting the wrong answer so I just have something wrong with the calculation.
USE space_data
IMPLICIT NONE
INTEGER :: i
delta_x = .2
DO i = 0, 5
idx = i*delta_x
END DO
END FUNCTION c_avg
EDIT
I just saw this in the module REAL :: exp, df !, erf, c, c_avg
It might not be reading what's after the exclamation point because it counts it as a comment.
K put in the t function stuff but I am still getting errors, how did you define your function within the main program? also what do you mean imput variables for dummy variables?
How exactly are you supposed to do the functions because that's what causing me the problems
oh for your computation problem was this the issue
The initial search interval [A,B] is given in years. The calculations require you to convert these
two into seconds.
 Likewise, the answer you get will be in seconds. You have to convert it back to years before you
print it out.
In your f function, you have two undeclared variables, c_avg and c_r. Did you intend to call your c_avg function inside f? If so, you have another problem - you are not calling c_avg correctly. When you call a function, you need to include parentheses after the function name.
I'm not sure what c_r is. If it's another function, I didn't find it, but I didn't look that carefully at your code. If c_r is a function, you aren't calling it correctly, either.
Code:
REAL FUNCTION f()
 USE space_data
 IMPLICIT NONE
 f = c_avg - c_r
 END FUNCTION f
I see problems in this code as well - t is undeclared. When you use IMPLICIT NONE, you HAVE TO declare all variables.
The other problem is that you are calling your c function and passing two arguments to it, but the definition of this function shows that it has no parameters.
Code:
 USE space_data
 IMPLICIT NONE
 INTEGER :: i
 delta_x = .2
DO i = 0, 5
 idx = i*delta_x
 END DO
 END FUNCTION c_avg
Code:
REAL FUNCTION c ()
 USE space_data
 IMPLICIT NONE
 REAL :: z, x
x=l
 z = x/(2*df*t)
 END FUNCTION c
BTW, using single letter names for functions (e.g., f and c) is not good programming practice. Almost every variable or function name should give a clear indication about what it is used for. The only exceptions are loop control variables such as i, j, etc.
hmm so all I have to do in terms of putting a function within a function is to put the parenthesis afterwards but won't it thinks its an array or something?
MODULE space_data
REAL :: L !LENGTH OF THE BAR
USE space_data
IMPLICIT NONE
CHARACTER :: choice
REAL :: f, root
INTEGER :: ercode
DO
READ(*,*) choice
SELECT CASE(choice)
CASE('A','a')
CALL call_data()
CASE('B','b')
CALL results()
CASE('Q','q')
STOP
END SELECT
END DO
CONTAINS
USE space_data
IMPLICIT NONE
READ(*,*) c_0
READ(*,*) d_0
READ(*,*) q
READ(*,*) temp
READ(*,*) l
READ(*,*) c_r
WRITE(*,*) ''
WRITE(*,*) ''
DO
READ(*,*) a
READ(*,*) b
IF(a < b) THEN
EXIT
ELSE
END IF
END DO
USE space_data
IMPLICIT NONE
INTEGER::I
REAL,EXTERNAL::F
!-3 UNKNOWN ERROR
X1=A
X3=B
F1 = F(X1)
F3 = F(X3)
IF(F1*F3>0) THEN
ELSE
D=1
I=0
D01=A-B
DO
X2 = (X1+X3)/2.
F2 = F(X2)
IF(D<EPS) THEN
ROOT = X2
ERCODE = 0 !SUCCESS
EXIT
EXIT
END IF
D = (X2-X1)/D01
F3 = F2
X3 = X2
D = (X3-X2)/D01
F1 = F2
X1 = X2
ROOT = X2
ERCODE = 0 !SUCCESS
EXIT
ELSE
EXIT
END IF
I = I+1
END DO
END IF
USE space_data
IMPLICIT NONE
WRITE(*,'(T5, "|", 1X, A,T40, "|", F12.2, 1X, "|")') 'Length of bar (m):',L
WRITE(*,*)
REAL FUNCTION Con()
USE Space_data
IMPLICIT NONE
REAL :: t,z,x,DF,delta_x,idx
INTEGER :: i
delta_x=L/5
t=(B-A)*31556926
DF=D_0*EXP(-q/(R*temp))
DO i = 0,5
idx=i*delta_x
z = idx/(2*DF*t)
con = (c_0/2.)*(1 - ERF(z))
END DO
END FUNCTION
REAL FUNCTION C_avg()
USE Space_data
IMPLICIT NONE
REAL,EXTERNAL :: Con
C_avg=(1/6)*Con()
END FUNCTION
REAL FUNCTION f()
USE Space_data
IMPLICIT NONE
REAL,EXTERNAL :: C_avg
f = C_avg()-C_r
END FUNCTION
The t (time) is either A or B which you have to ask for as the input (10 and 50 in the pdf). When the program runs, it will evaluate the function(s) for these two times, but they have to be in seconds. We only care about the end of the bar so X or delta X will always just be the length of the bar, then these are only functions of time.
I don't want to post my code here but if you go to the lab on Thursday I can show you how I did the functions.
Oh yeah, it says the time input is in years, but it's actually days, so when you convert A and B to seconds, make sure you convert from days to seconds, not years to seconds.
So my code compiles but now i get an error when I put in data and enter choice b
it says exception access violation
traceback not available
Not if you have declared your variables (including arrays) and functions properly. From the declarations, the compiler can tell the difference between a function call and an array.
When you call a function there is more to it than just putting a pair of parentheses after the function name. The number of parameters in the function call has to agree with the number of parameters in the function definition. Also, the types of the parameters have to agree.
So now you need to do some debugging. Entering 'b' for the choice causes your program to call your bisection subroutine, and then the results routine. If you have a debugger available, it would be good to learn how to use it. If using a debugger is not an option, you can use the oldest debugging technique, which is to insert output statements in your code so that your program displays the values of variables. You should be able to predict what the values of variables will be by hand calculation.
I'm guessing that the exception you're seeing results from attempting to access an array using an index that's out of range.
Did anyone find a solution to this? my project has the same error.
Did you try what I suggested a couple of posts ago?
1. What is carburization and why is it important?
Carburization is a process in which carbon is diffused into the surface of a metal to increase its carbon content. This is important because it can improve the hardness and strength of the metal, making it more suitable for certain applications.
2. How is time calculated in carburization using the bisection method?
The bisection method is a numerical method that involves dividing an interval into smaller sub-intervals to find the root of a function. In carburization, this method can be used to calculate the time required for the carbon to diffuse into the metal by finding the time at which the carbon concentration reaches a desired level.
3. What factors affect the accuracy of the bisection method in carburization time calculations?
Some factors that can affect the accuracy of the bisection method in carburization time calculations include the initial carbon concentration, temperature, and composition of the metal. Other variables, such as the diffusion coefficient and thickness of the metal, can also impact the accuracy of the method.
4. Is the bisection method the only way to calculate carburization time?
No, there are other methods that can be used to calculate carburization time, such as the finite difference method and the analytical method. Each method has its own advantages and limitations, and the most suitable method may vary depending on the specific scenario.
5. How can the bisection method be applied in real-world carburization processes?
The bisection method can be applied in real-world carburization processes by using mathematical models to represent the diffusion of carbon into the metal. These models can then be solved using the bisection method to estimate the time required for carburization. However, it is important to note that the results from this method should be validated with experimental data to ensure accuracy.
22K
