Fortran - Read unformatted > Write formatted
  1. Oct 15, 2009 #1
    minger
    I guess this is really a bug check. I'm having problems converting an unformatted CFD file to a formatted file so that I can manipulate the data, etc, etc. Below is what I'm doing, if anyone sees anything that jumps out I would REALLY appreciate it.
    Code (Text):
    PROGRAM unformattedConverter
    IMPLICIT NONE
    INTEGER :: i,j,k,n,m,nBlocks,type
    INTEGER,DIMENSION(:),ALLOCATABLE :: ni,nj,nk
    REAL :: mach,alpha,reyn,time
    REAL,DIMENSION(:,:,:,:),ALLOCATABLE   :: x,y,z
    REAL,DIMENSION(:,:,:,:,:),ALLOCATABLE :: q
    CHARACTER(len=24) :: filename
    WRITE(6,*) 'Enter the unformatted file to convert'
    READ*, filename
    WRITE(6,*) 'Enter 0 for grid file, or 1 for flow file'
    READ*, type
    OPEN(11,file=filename,form='unformatted')
    READ(11) nBlocks
    ALLOCATE( ni(nBlocks),nj(nBlocks),nk(nBlocks) )
    READ(11) (ni(n),nj(n),nk(n),n=1,nBlocks)
    IF (type .EQ. 0) THEN
      ALLOCATE( x(MAXVAL(ni),MAXVAL(nj),MAXVAL(nk),nBlocks),&
                y(MAXVAL(ni),MAXVAL(nj),MAXVAL(nk),nBlocks),&
                z(MAXVAL(ni),MAXVAL(nj),MAXVAL(nk),nBlocks) )
      DO n=1,nBlocks
        READ(11) (((x(i,j,k,n),i=1,ni(n)),j=1,nj(n)),k=1,nk(n)),&
                 (((y(i,j,k,n),i=1,ni(n)),j=1,nj(n)),k=1,nk(n)),&
                 (((z(i,j,k,n),i=1,ni(n)),j=1,nj(n)),k=1,nk(n))
      END DO
      OPEN(13,file='gridOutput.fast',form='formatted')
      WRITE(13,*) nBlocks
      WRITE(13,*) (ni(n),nj(n),nk(n),n=1,nBlocks)
      DO n=1,nBlocks
        WRITE(13,*) (((x(i,j,k,n),i=1,ni(n)),j=1,nj(n)),k=1,nk(n)),&
      END DO
      CLOSE(13)
      DEALLOCATE( x,y,z )
    ELSEIF (type .EQ. 1) THEN
      ALLOCATE( q(MAXVAL(ni),MAXVAL(nj),MAXVAL(nk),nBlocks,5) )
      DO n=1,nBlocks
        READ(11) mach,alpha,reyn,time
        READ(11) ((((q(i,j,k,n,m),i=1,ni(n)),j=1,nj(n)),k=1,nk(n)),m=1,5)
      END DO
      OPEN(14,file='flowOutput.fast',form='formatted')
      WRITE(14,*) nBlocks
      WRITE(14,*) (ni(n),nj(n),nk(n),n=1,nBlocks)
      DO n=1,nBlocks
        WRITE(14,*) mach,alpha,reyn,time
        WRITE(14,*) ((((q(i,j,k,n,m),i=1,ni(n)),j=1,nj(n)),k=1,nk(n)),m=1,5)
      END DO
      CLOSE(14)
      DEALLOCATE( q )
    END IF
    DEALLOCATE( ni,nj,nk )
    END PROGRAM
    In the output, it doesn't seems like its correctly reading nj, nk, or q (when I choose to read it).
Draft saved Draft deleted
Loading...
