What could be causing a segmentation fault in this Fortran function?
In summary, the conversation mainly revolves around a segmentation fault that the user is experiencing when running a Fortran program. They discuss potential causes of this error, including accessing memory locations that should not be accessed and declaring arrays with insufficient space. They also mention the use of a debugger to help identify the problem, but the user is unsure which debugger to use. They also discuss the importance of testing and debugging code in small steps, rather than writing a large program all at once. Finally, they mention an error that they encountered when trying to use a different compiler, and ask for help in understanding why this error occurred.
ASGtFT
1. I have a segmentation fault when I try to run a program I have written in Fortran. The compiler I used is gfortran. What typically causes a segmentation fault, and how do I find where the problem is? I know I should use a debugger, but I don't know which debugger I should use, how to get it, or how to use it (I don't know whether it is Fortran 95, 03 or 08--how do I find out?).
Generally, a segmentation fault is caused by trying to access a memory location you shouldn't. This can happen, for instance, if you declare an array to have 10 elements but try to access the 100th element.
Debugging is a bit of an art. If the program isn't too complicated, the first thing I'd do is look carefully through the source code for obvious errors. You can also insert write statements to report the values of variables at various points in the program to make sure your algorithm is working the way you expect it to.
As far as debuggers go, I can't really offer any advice as I've rarely needed to use one. Since gfortran is a Gnu product, I'd expect gdb to work with it, but a little Googling suggests that combination did not work too well in the past. Perhaps things have improved since then.
I should probably add a little background. My code performs an algorithm on some data in an input file. But the code works perfectly for small files, and only segfaults for larger files. That doesn't seem to make sense if the problem is simply to do with an invalid location.
Show us your code, and we can most likely figure out why it's generating an error.
If you paste your code into the text window here, put a [ code] tag at the top of it, and a [ /code] tag at the bottom. Omit the space right after the left bracket, though.
Segmentation faults are catch-alls, usually indicating Some Major Problem. Such as giving a library data of the wrong type, or anything totally unexpected, really.
But it really points to there being problem with your approach to developing your computer program. You should start off with a program that does nothing much more complex than print Hello World, then add in extra code and calls to subroutines in measured steps, each time checking that it is still all working so far. : :smile: As soon as a compiler or runtime error shows up, :grumpy: you can immediately identify what changes/additions caused the error to arise.
If you type up the whole program, and throw it all at the compiler, unless you are an accomplished programmer, there will be dozens of errors, most tiny, some major. It can pose a headache and be just too unwieldy to untangle.
Start out modest, and build up towards your final masterpiece, with lots of testing along the way. It sounds arduous, but you soon pick up speed.
I suppose you have successfully compiled small test programs with that compiler? If not, then the problem might not lie with the code you are writing at all, it might be that the compiler software itself isn't installed correctly on your PC.
That's exactly the type of situation that can cause a segfault. Say your program loads all the input data into an array and you wrote the program assuming that at most you'll have, say, 100 pieces of input data. There'd be no spot in the array for the 101st piece of data, which means your program tries to access a memory location beyond the end of the array, possibly causing a segmentation fault.
I have a vague recollection that arrays can default to a small 'subscript', say maximum of 10, and if you need them to go to higher subscripts you need an explicit DIM statement. (Gee, it's a long time since I wrote anything in MNF.)
That would make sense. My code deals with many arrays. One problem with my code (which may or may not have led to the segmentation fault) is that it doesn't seem to be portable. I started out using gfortran, and today I tried to use NAG (somebody told me that it was easier to debug). However, I suddenly couldn't even compile the program, and got this error:
Error: cell_vertexc_mod.f90, line 357: USE CELL_VERTEX in program-unit RECOUNT_MEMBER imports symbol RECOUNT_MEMBER
detected at CELL_VERTEX@<end-of-statement>
I don't understand why this is an error. All I am doing here is using an interface in another file. Why wouldn't this be allowed?
Thank you for offering to look at the code, but there's quite a lot of it (about 900 lines now), and I wouldn't want anyone to spend ages working their way through it when they have better things to do!
Whatever compiler you use should have options to generate bounds checking code for arrays and other accesses. For gfortran, for example, the command line option -fcheck=bounds. It should catch your error and report a line number where it occurred.
Do I use the command in runtime, or in compiling? I used it in runtime using:
./{program file} -fcheck=bounds
Is that what the usual command is? Also, do you know of any gfortran manuals I can find? All I can find is this one: http://gcc.gnu.org/onlinedocs/gcc-4.0.4/gfortran/index.html#toc_Invoking-GFORTRAN
But I'm not really sure where to find the information I need. The layout is slightly confusing.
Thanks!
Thanks!
It would be a compile time option, since the compiler must generate code to check these things.
Have a look http://gcc.gnu.org/onlinedocs/gcc-4.5.3/gfortran/Code-Gen-Options.html#Code-Gen-Options".
I tried it, but it didn't show any errors. I assume that this means that the array sizes are fine, although this seems to contradict the fact that the program only segfaults for larger files. Can you give me exact command you would use? I used:
gfortran program_name -fcheck=bounds module1.f90 module2.f90 program_name.f90
To me your command line looks okay. Sorry, not much more I can suggest at this point except looking for other similar debugging switches to enable. Without having the code in-hand, it's just shooting in the dark :smile:
Thanks. I'll try some others on that link you sent me.
Hi, I've managed to find where the problem is, but I can't see what it is. This is the function that appears to be causing the segfault. Can anyone tell me what the problem might be? Thanks!
Code:
FUNCTION pairing (list1, list2, fbpt, last) RESULT (paired)
use cell_test, except_this_one => pairing
IMPLICIT NONE
LOGICAL paired
TYPE (cell), TARGET, INTENT(IN):: list1, list2
TYPE (cell), POINTER, INTENT(INOUT):: fbpt
TYPE (cell), POINTER, INTENT(INOUT):: last
LOGICAL :: found = .FALSE.
INTEGER :: i, j, k
INTEGER, DIMENSION(2):: tedge
TYPE (cell), POINTER :: pt1, pt2
found = .FALSE.
paired = .FALSE.
pt1 => list1
pt2 => list2
!print *, "pairng #1"
tedge = (/0,0/)
loop2:DO while(associated(pt2))
   if(pt2%vertex(1) .eq. Tagged) then
       pt2=> pt2%next
   end if
   if(pt1%myself%index .eq. pt2%myself%index) then
      pt2 => pt2%next
   end if
   if (.not. associated(pt2)) then
      found = .FALSE.
      paired = .FALSE.
      exit loop2
   end if
   call find_fedge (pt1%myself%vertex, pt2%myself%vertex, pt1%myself%vsize, pt2%myself%vsize, found, tedge)
   if (found) then
   write (7,*) "paring:: found, the edge is =", (tedge(i), i=1, 2)
   write ( 7, '(A8,8x,I3,1x,I3,1x,A4,1x,I3,1x,I3)') &
   "paring::",pt1%index,pt1%myself%index,"cell", pt2%index,pt2%myself%index
   write ( 7, '(A9,7x,15I5)')  "paring:1:",(pt1%myself%vertex(i), i=1, pt1%myself%vsize)
   write ( 7, '(A9,7x,15I5)')  "paring:2:",(pt2%myself%vertex(i), i=1, pt2%myself%vsize)
      tedge = (/0,0/)
      allocate(fbpt%myself)
      fbpt => fbpt%myself
      nullify(fbpt%prev)
      nullify(fbpt%next)
      nullify(fbpt%myself)
      !print *, "pairng:: #8 %next => pt2, %prev => pt1"
      fbpt%next => pt2
      fbpt%prev => pt1
      fbpt%next%vertex(1) = Tagged
      fbpt%prev%vertex(1) = Tagged
      last => pt2
      paired = .TRUE.
      exit loop2
   else
      found = .FALSE.
      paired = .FALSE.
      pt2 =>pt2%next
   end if
END DO loop2
END FUNCTION pairing
The rest of the code (including those bits that it uses and calls) seems to be fine. It's just this function.
1. What is a "Fortran segmentation fault"?
A "Fortran segmentation fault" is an error that occurs when a program written in the Fortran programming language tries to access a memory location that it does not have permission to access. This can happen due to a variety of reasons, such as a bug in the code or an attempt to access an uninitialized variable.
2. How does a "Fortran segmentation fault" affect my program?
A "Fortran segmentation fault" can cause your program to crash or behave unexpectedly. It is a critical error that needs to be addressed in order for your program to function properly.
3. How can I debug a "Fortran segmentation fault"?
Debugging a "Fortran segmentation fault" can be a challenging task, but there are a few steps you can take to identify and fix the issue. This includes using a debugger, checking for uninitialized variables, and examining the code for potential bugs or memory access violations.
4. Can external factors cause a "Fortran segmentation fault"?
Yes, external factors such as hardware issues or insufficient memory can also lead to a "Fortran segmentation fault". It is important to rule out these possibilities before assuming that the error is caused solely by the code.
5. How can I prevent "Fortran segmentation faults" in my code?
To prevent "Fortran segmentation faults", it is important to write well-structured and error-free code. This includes properly declaring and initializing variables, avoiding out-of-bounds memory access, and handling errors and exceptions effectively. It is also helpful to use debugging tools and techniques during the development process to catch and fix potential issues before they cause a segmentation fault.
