Fortran Fortran Write Path
  1. Mar 11, 2015 #1
    Hello,
    I have write a fortran code to write several file, like this
    CHARACTER(len=12) :: FNAME
    INTEGER::ST
    DO 100 ST=1,12
    DO KC=1,4 !number of layer
    IF(ST.EQ.1) WRITE (FNAME,10)KC
    IF(ST.EQ.2) WRITE (FNAME,11)KC
    IF(ST.EQ.3) WRITE (FNAME,12)KC
    IF(ST.EQ.4) WRITE (FNAME,13)KC
    IF(ST.EQ.5) WRITE (FNAME,14)KC
    IF(ST.EQ.6) WRITE (FNAME,15)KC
    IF(ST.EQ.7) WRITE (FNAME,16)KC
    IF(ST.EQ.8) WRITE (FNAME,17)KC
    IF(ST.EQ.9) WRITE (FNAME,18)KC
    IF(ST.EQ.10) WRITE (FNAME,19)KC
    IF(ST.EQ.11) WRITE (FNAME,20)KC
    IF(ST.EQ.12) WRITE (FNAME,21)KC
    WRITE(6,*)FNAME
    OPEN(1,FILE=FNAME)
    CLOSE(1)
    END DO
    10 FORMAT('XY01UA',I2.2,'.DAT')
    11 FORMAT('XY02UA',I2.2,'.DAT')
    12 FORMAT('XY03UA',I2.2,'.DAT')
    13 FORMAT('XY04UA',I2.2,'.DAT')
    14 FORMAT('XY05UA',I2.2,'.DAT')
    15 FORMAT('XY06UA',I2.2,'.DAT')
    16 FORMAT('XY07UA',I2.2,'.DAT')
    17 FORMAT('XY08UA',I2.2,'.DAT')
    18 FORMAT('XY09UA',I2.2,'.DAT')
    19 FORMAT('XY10UA',I2.2,'.DAT')
    20 FORMAT('XY11UA',I2.2,'.DAT')
    21 FORMAT('XY12UA',I2.2,'.DAT')
    100 CONTINUE
    STOP
    END
    Those codes are works fine.
    I only wanna know, how to change all of this files' path to another folder inside the main program folder.
    Thanks in advance,
    Shade
  3. Mar 11, 2015 #2
    DrClaude
    Staff: Mentor
    Add another character variable containing the path, then concatenate both when opening:
    Code (Fortran):
    CHARACTER(len=80) :: PATH
    PATH = "./subfolder/"
    open (1,FILE=trim(PATH)//FNAME)
    The use of trim is necessary if PATH has a length greater than the actual path name.
    Note that, for better practice, the series of if statements should be replace by a select case. Your program could also be more readable by incorporating the format inside the write statements, e.g., use
    Code (Fortran):
    WRITE (FNAME,"('XY01UA',I2.2,'.DAT')") KC
    instead of
    Code (Fortran):
    WRITE (FNAME,10)KC
    ! lots of code
  4. Mar 11, 2015 #3
    DrClaude, you save the day! Thank you very much. Now it's all good.
