Need Help with Writing Fortran95 Procedure
In summary, the problem is that you have to calculate values for each molecule in each row of the input files.
anna2011
Fortran95 HELP!
Hi everyone,
I have problem with writing a procedure in Fortran. I'm a newbie so any help will be appreciated.
So the problem is as follow: I have written a program which reads some data from input file and then calculates some stuff using read values. Now what i have to do is to open more then just one file (seven actually) which have the same format as the previous one, the same extention but different names and the text string is not composed of the same number of letters, just the same extension. When i open all the files then i have to use the procedure i wrote and write all the data in one file.
Can anyone tell me how I can do that, I'm getting crazy becuase of that...
Thanks, in advance
Technology news on Phys.org
I think opening and writing is done as follows
Forgive me if I misunderstand your question
open(1,file='file1')
open(2,file='file2')
open(7,file='file7')
write(1) variable1
write(2) variable2
write(7) variable7
close(1,2,3,4,5,6,7)
Hi,
Thanks for quick reply.
So the idea is to read seven files, one by one, read from those files needed values and use the same procedure to calculate some values based on data read from each input file. And then in output file i should have seven separate blocks of calculations, for each input file.
Is this makes things more clear?
anna2011 said:
Hi,
Hi anna :smile: I am new to FORTRAN as well, but I think you need to do something like this:
1) Initialize some arrays to store the data in
2) Open all of the files
3) Use a "DO" loop to read all of the data into the arrays
4) Close all files
We can help you out, but it would be helpful if you could provide a short sample of one of the 7 files you wish to get data from. Just copy paste the first 5-6 rows of data from a file and wrap them in the "Code" tags located above by using the [URL]http://i12.photobucket.com/albums/a220/saladsamurai/codetags.jpg[/URL] button (this will preserve the formatting).
Code:
C1        2.1419561858E+00  2.1419561858E+00  4.2839123717E+00  0.0000000000E+00
O2        4.5849316264E+00  4.5849316264E+00  9.1698632528E+00  0.0000000000E+00
N3        4.0198698574E+00  4.0198698574E+00  8.0397397149E+00  0.0000000000E+00
H4        3.0070127032E-01  3.0070127032E-01  6.0140254064E-01  0.0000000000E+00
H5        3.1607842405E-01  3.1607842405E-01  6.3215684811E-01  0.0000000000E+00
N6        4.0198675021E+00  4.0198675021E+00  8.0397350042E+00  0.0000000000E+00
H7        3.0070127037E-01  3.0070127037E-01  6.0140254074E-01  0.0000000000E+00
H8        3.1606930741E-01  3.1606930741E-01  6.3213861481E-01  0.0000000000E+00
hope its enough.
Thanks a lot :)))
anna2011 said:
Code:
hope its enough.
Thanks a lot :)))
Hmm I'm afraid it's not enough. Could you explain what are those values for your program? These are the written values, the read ones?
Also they are weird (but might be right). For each molecule (or row I'd better say), the first column is equal to the second. And the 3rd column is worth 2 times the first. The last is always 0.
write(1) variable1
write(2) variable2
write(7) variable7
You forgot to read the files and do some calculations :)
What is Fortran95?
Fortran95 is a programming language commonly used in scientific and engineering applications. It is an updated version of the original Fortran language and was released in 1995.
Why do I need help with writing Fortran95 procedures?
Writing procedures in Fortran95 can be complex and challenging, especially for those who are new to the language. It is important to have a good understanding of the language and its syntax in order to write efficient and error-free procedures.
Where can I find help with writing Fortran95 procedures?
There are many resources available online for learning Fortran95 and getting help with writing procedures. Some examples include online tutorials, forums, and documentation from the Fortran95 language developers.
What are the key components of a Fortran95 procedure?
A Fortran95 procedure typically consists of a header, which includes the subroutine or function name, input and output parameters, and any other necessary declarations. The body of the procedure contains the actual code and may also include control statements and comments.
How can I improve my Fortran95 procedure writing skills?
Practice and familiarizing yourself with the language syntax are key to improving your Fortran95 procedure writing skills. You can also benefit from studying well-written code and seeking feedback from experienced Fortran programmers.
