Homework Help: Foundation System
  1. Nov 9, 2012 #1
    Again, I have a question where I have not idea what I did wrong... Please give suggestions! Thanks. Work is shown on attachment.
    You have a foundation wall system in the field that you were asked to determine the load capacity of per lineal foot. The wall has the following measurements and specifications:
    Specifications:
    f c' = 3,000 psi f y = 40,000 psi Allowable soil bearing capacity = 4,000 psf
    Wall loads: live = three times the dead load per foot
    dead = one third the live load per foot
    Cover for footer steel = 3”
    #4 rebar at 9” center to center for main steel
    ___ - #5 rebar for temperature steel
    Wall load includes the weight of the wall however not the weight of the footer.
    Wall thickness = 8” Footer depth: h = 16” Footer width: w = 4’- 6”
    Note: Perform and show all code check considerations.
    Maximum unfactored live load the wall footer can safely carry: __11385______ #/’
    Maximum unfactored dead load the wall footer can safely carry: ____3795____ #/’
    Area of longitudinal steel: __1.728_____ sq in __6_____ - # 5 bars
    2. Relevant equations
    3. The attempt at a solution
    View attachment question3.pdf
  3. Nov 11, 2012 #2
    CWatters
    Not my field but..
    I notice the question says "4000 psf". I might be wrong but your answer sheet appears to say "T = 4000 psi" ?
  4. Nov 11, 2012 #3
    You are correct. I miss labeled it. This would not affect the answers
