• Support PF! Buy your school textbooks, materials and every day products Here!
Fountain Power Question
  • Thread starter kitty9035
A fountain sends a stream of water 28.8 m up into the air. The acceleration of gravity is 9.8. IF the base of the stream is 4.38 cm in diameter, what power is required to send the water to this height?
I was thinking maybe using bernoulli's equation to find the pressure and plug into to the formula work=pressure x volume. Then plug the answer for work into power=work/delta t.
Then i was thinking how do u find the time.. so i used the equation t= the square root of 2gh.
Is my though process correct? Any hints?? tHANKS IN ADVANCE
Answers and Replies
i believe work = pressure * velocity
are u sure u need to find the time
Power = Force * Velocity as well =).
You have the right idea though that you would be using an equation where you get a square root of 2g(delta y). But the problem is that your equation isn't solving for time! Think about what you need =).
Pressure = Force / Area; use basic algebra to solve for Force. But problem, you don't have the pressure =). Solve for it.
You know the "rho" of water (density). There's an equation to get a pressure =).
I solved for the Force by finding the mass and multiplying it by 9.8. Now I'm having trouble finding the velocity
Related Threads for: Fountain Power Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
  • Last Post
