Four bar linkage forward kinematics question
Hi, this is my first post on this forum.
I have a design for a machine with two mutually perpendicular revolute joints, i.e.
a base,
a hinged joint,
an arm,
a hinge perpendicular to the first joint,
second arm.
Using D-H forward kinematics I've got code working using 4*4 transformation matrices.
Now, there's a proposal to change one of the revolute joints to a 4-bar linkage.
All the joints in the new linkage will be parallel to the original axis.
(ASCII art attempt:)
(+ = joint)
becomes
--------I--------
---+__I___+
-+__________+
This means the simple revolute joint must be replaced by four
offset parallel revolute joints, which form a closed loop.
The simplicity of the original arrangement meant it was quite straightforward
to do the kinematics. The proposed arrangement has me confused.
So, I _think_ I need to replace the simple 4*4 matrix describing a revolute joint,
with a matrix describing the 4-bar linkage.
The treatments I've found are too general for me to figure it out.
Can anyone out there help me? How do I derive the new matrix?
Or is there a better approach?
Winston
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
