Fourier series and transforms
In summary, Fourier series is a method of representing a periodic function as a combination of sines and cosines or complex exponentials. There is a proof that shows how any integrable periodic function can be approximated accurately by a Fourier series. However, for dis-continuous functions, this approximation only holds for a set of measure 0. On the other hand, it is difficult to show that a valid Fourier series can converge to a non-Riemann-integrable function, which led to the development of Lebesque integration.
rakeshbs
Fourier series is a way to express a periodic function as a sum of complex exponentials or sines and cosines.. Is there actually a proof for the fact tat a periodic function can be split up into sines and cosines or complex exponentials?
Mathematics news on Phys.org
It is fairly easy to show that any integrable periodic function can be approximated arbitrarily well by a sum of sines and cosines. The Fourier series is the limit of those approximations as the "error" goes to 0- except on a set of measure 0 for dis-continuous functions. I might point out that the other way is what's hard. It can be shown that some perfectly valid Fourier series converge to non-(Riemann)-integrable functions. That was why Lebesque integration had to be invented.
Yes, there is a mathematical proof for the fact that a periodic function can be expressed as a sum of sines and cosines or complex exponentials. This proof is known as the Fourier series representation theorem and it was first introduced by French mathematician Joseph Fourier in the early 19th century.
The proof involves using the complex exponential function, which is defined as e^ix = cos(x) + i*sin(x), to represent a periodic function. By using this representation, we can express any periodic function as a combination of different frequencies and amplitudes, which can be represented by the coefficients in the Fourier series.
The key idea behind this proof is that any periodic function can be decomposed into a sum of harmonic functions, which are functions with frequencies that are integer multiples of the fundamental frequency. By using the complex exponential function, we can express these harmonic functions as sines and cosines, which are easier to work with mathematically.
Overall, the proof for the Fourier series representation theorem involves a lot of mathematical concepts and techniques such as complex analysis, trigonometry, and calculus. It is a fundamental result in mathematics and has many important applications in fields such as signal processing, engineering, and physics.
What is a Fourier series and transform?
A Fourier series and transform is a mathematical tool used to represent a periodic function as a sum of sine and cosine functions with different frequencies and amplitudes. It can also be used to analyze the frequency components of a signal or function.
What is the difference between a Fourier series and a Fourier transform?
A Fourier series is used to represent a periodic function, while a Fourier transform is used to analyze a non-periodic function. A Fourier series uses discrete frequencies, while a Fourier transform uses continuous frequencies.
What is the importance of Fourier series and transforms in science and engineering?
Fourier series and transforms are widely used in fields such as signal processing, physics, and engineering to analyze and manipulate signals and functions. They are essential in understanding the frequency components of a system and can help in solving differential equations and other mathematical problems.
How are Fourier series and transforms calculated?
There are various mathematical formulas and techniques for calculating Fourier series and transforms, such as the Fourier series coefficients, Fourier transform integral, and discrete Fourier transform algorithm. These methods involve complex mathematical calculations and may require the use of computer software.
What are some practical applications of Fourier series and transforms?
Fourier series and transforms have numerous applications in science and engineering, including image and sound processing, data compression, and solving differential equations. They are also used in fields such as astronomy, chemistry, and economics to analyze and understand complex systems and phenomena.
  • General Math
