Homework Help: Fourier series change of variable
  1. Jul 4, 2006 #1
    Hi, I'm working on the (odd) square wave function
    [tex]
    f\left( t \right) = \left\{ {\begin{array}{*{20}c}
    { - 1, - \frac{T}{2} \le t < 0} \\
    { + 1,0 \le t < \frac{T}{2}} \\
    \end{array}} \right\}
    [/tex]
    The question says to move the origin of t to the centre of an interval in which f(t) = +1 (ie. consider the even square wave function). A part of the question says to express the square wave function as a cosine series by making the change of variable [itex]t' = t - \frac{T}{4}[/itex].
    Calculate the Fourier coefficients involved by making the suggested change of variables in the result 12.8
    Result 12.8 is:
    [tex]
    f\left( t \right) = \frac{4}{\pi }\left( {\sin \omega t + \frac{{\sin 3\omega t}}{3} + \frac{{\sin 5\omega t}}{5} + ...} \right)...(12.8)
    [/tex]
    This isn't apart of result 12.8 but the sine Fourier coefficients are:
    [tex]
    b_r = \frac{2}{{\pi r}}\left[ {1 - \left( { - 1} \right)^r } \right]
    [/tex]
    I don't know how to calculate the coefficients for the cosine series using (12.8) and the change of variables t' = t - (T/4). Using the sin(A+B) expansion for each sine term in result 12.8 is tedious so should I write f(t) as follows and then use the sine addition formula on the general sine term?
    [tex]
    f\left( t \right) = \sum\limits_{r = 1}^\infty {\frac{2}{{\pi r}}\left[ {1 - \left( { - 1} \right)^r } \right]\sin \left( {\frac{{2\pi rt}}{T}} \right)}
    [/tex]
    I probably haven't analysed the information carefully enough but I'm not sure how to start this. I've only just started on Fourier series. Any help would be good thanks.
Draft saved Draft deleted
