How can you find the Fourier series of Sin[x] with a period other than 2n Pi?
In summary, the Fourier series of sin(x) only works if ao, an, and bn go to zero. However, if n is not 1, bn is still zero.
misterme09
I know it's trivial...but how do you find the Fourier series of sin(x) itself? I seem to get everything going to zero...
You should. The Fourier series of sin(x) is simply sin(x). This is like asking what the Taylor series of y=x^2 is.
Yes, but if the Fourier series of f(x) = ao/2 + sum over n from 1 to infinity (an*cos(n*x) + bn*sin(nx)) then if ao, an, and bn go to zero, you are left with simply zero as the Fourier series. Shouldn't this method still work?
What ever makes you think all of the terms go to zero? One term does not, the b1 term. You end up with sin(x).
bn = (1/pi) int ( sin(x) * sin(n*x) dx) from -pi to pi becomes a multiple of sin (n*pi) which is always zero.
if n = 1, then it's the integral of sin^2x, which is certainly not zero over -pi to pi.
That's true. Okay, but for bn where n isn't 1, bn is zero, correct?
Correct
Sorry to gravedig, but considering this is the first result for the Fourier series of sin[x]. I had to correct it.
A Fourier series is a series that has a period equal to part of a qualified f(x) from -L to L or 0 to 2l.
Yes, the Fourier series of Sin[x] with L = 2n Pi where n is an element of Z is simply Sin[x].
But the Fourier series of Sin[x] with L =/= 2n Pi is NOT Sin[x].
Look at the graph of Sin[x] from 0 to Pi/2. If you wanted a function that repeated that period, Sin[x] would no-where near work.
The first few terms of that Fourier series would be: (4 Cos[1/2] Sin[x])/(-1 + \[Pi]^2) + (
8 Cos[1] Sin[2 x])/(-4 + \[Pi]^2) + (
12 Cos[3/2] Sin[3 x])/(-9 + \[Pi]^2)
According to mathematica. (It's slightly incorrect, since the outcome of the periods are off. Working on it)
1) What is a Fourier series?
A Fourier series is a mathematical representation of a periodic function as the sum of sine and cosine waves. It is used to decompose a complex function into simpler components.
2) Why is the Fourier series of sin(x) important?
The Fourier series of sin(x) is important because it is a fundamental building block in the theory of Fourier series, which has many practical applications in mathematics, physics, and engineering. It also helps us understand the behavior of periodic functions and how they can be represented as a sum of simpler functions.
3) How is the Fourier series of sin(x) calculated?
The Fourier series of sin(x) can be calculated using the Fourier coefficients, which are calculated by taking the inner product of the function with a sine or cosine function. The coefficients are then used to form an infinite series that represents the original function.
4) What is the convergence of the Fourier series of sin(x)?
The Fourier series of sin(x) is absolutely and uniformly convergent, meaning that the series converges to the original function for all values of x. This makes it a useful tool for approximating periodic functions.
5) How is the Fourier series of sin(x) used in real-world applications?
The Fourier series of sin(x) has many practical applications, including signal processing, image compression, and solving differential equations. It is also used in various fields such as physics, engineering, and finance to model and analyze periodic phenomena.
  • Calculus
  • Calculus
  • General Math
