Fourier series proof
PhysicsMark
91
Suppose, in turn, that the periodic function is symmetric or antisymmetric about the point x=a. Show that the Fourier series contains, respectively, only [tex]cos(k_{n}(x-a))[/tex] (including the [tex]a_0[/tex]) or [tex]sin(k_{n}(x-a))[/tex] terms.
The Fourier expansion for the periodic function, f(x):
[tex]f(x)=a_0 + \sum_{n=1}^{\infty}(a_{n}cos(k_{n}x) + b_{n}sin(k_{n}x))[/tex]
[tex]a_0=\frac{1}{\lambda}\int_{x_0}^{x_0+\lambda}f(x) dx[/tex]
[tex]a_n=\frac{2}{\lambda}\int_{x_0}^{x_0+\lambda}f(x)cos(k_{n}x) dx, n\neq0[/tex]
[tex]b_n=\frac{2}{\lambda}\int_{x_0}^{x_0+\lambda}f(x)sin(k_{n}x) dx, (b_0=0)[/tex]
[tex]k= \frac{2n\pi}{\lambda}\qquad \lambda=period[/tex]
Hint: An integral centered on a point where the integrand is antisymmetric will vanish.
I believe I understand what they are saying, but I do not know how to show/prove it. I know that cosine is symmetric about a point, while sine is not. Initially I was thinking that since sine is antisymmetric, for f(x) to be symmetric, the sine terms cannot exist in the expansion (which is exactly what the problem states). I was thinking the same for the opposite case regarding cosines.
The hint leads me to believe I am supposed to set up an integral. However, I do not understand how.
If I am to set up an integral, the best I can figure is that the lower limit should be [tex]a-\lambda[/tex] and the upper limit should be [tex]a+\lambda[/tex]
I think this because for the integral to be centered at point "a", we would need to go 1 full period in both directions.
Answers and Replies
PhysicsMark
91
Something just dawned on me. Does anyone think the following is correct?:
If f(x) is symmetric, then b_n is 0 since sine is antisymmetric. Therefore, the sin term in the Fourier series drops out.
If f(x) is antisymmetric, then a_n is 0 since f(x) is antisymmetric and the cosine term in the Fourier series drops out.
vela
Staff Emeritus
Education Advisor
15,514
2,159
Yup, that's exactly what the hint was getting at.
PhysicsMark
91
Thanks! I can't believe I burned almost 3 hours on that, only to have the answer as soon as I posted it.
Suggested for: Fourier series proof
  • Last Post
9K
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
