Fourier series summation .help
In summary, a Fourier series summation is a mathematical technique used to represent a periodic function as a sum of sine and cosine functions. It is calculated by finding the coefficients of these functions using integration or other methods. The purpose of using this technique is to simplify the representation of a complex function and analyze its behavior. It can only be used for periodic functions, but there are other techniques for non-periodic functions. Some real-world applications of Fourier series summation include signal processing, image compression, and solving differential equations in various fields such as physics, engineering, and economics.
thelegend09
Fourier series summation...help!
Basically, i need to show that...
2 + sum (m=1 to n) [4(-1)^m . cos(m.pi.x)] = 2(-1)^n.cos((n+1/2)pi.x)/cos((pi.x)/2)
Any ideas?
[tex]2 + \sum_{m=1}^n 4(-1)^m\cos{(m\pi x)} = 2(-1)^n\cos((n+\frac{1}{2})\pi x)/\cos{(\pi x/2})[/tex]
Try writing the right side function as a Fourier series.
AM
Sure, I'd be happy to help! Fourier series summation is a mathematical technique used to represent a periodic function as an infinite sum of trigonometric functions. In this case, we are looking at the specific example of a Fourier series summation involving the cosine function.
To begin, let's take a closer look at the equation that you provided:
This equation can be broken down into two parts: the first term, 2, and the summation term. The summation term can also be expressed as a product of two parts: the coefficient, 4(-1)^m, and the cosine function, cos(m.pi.x).
Now, let's focus on the summation term. This is a sum of cosines with different frequencies, as determined by the value of m. As m increases, the frequency also increases. This means that as we add more terms to the summation, the function becomes more and more complex, with more "waves" being added to the original function.
However, as we approach infinity, the function becomes smoother and smoother, eventually converging to a single function. In this case, the function we are converging to is 2(-1)^n.cos((n+1/2)pi.x)/cos((pi.x)/2). This function has a frequency of (n+1/2)pi, which is the highest frequency in the original summation.
So, to summarize, the Fourier series summation allows us to represent a periodic function as an infinite sum of simpler trigonometric functions, with the complexity increasing as we add more terms, but eventually converging to a single function.
I hope this explanation helps to clarify the concept of Fourier series summation for you. If you have any further questions, please feel free to ask. Good luck with your work!
1. What is a Fourier series summation?
A Fourier series summation is a mathematical technique used to represent a periodic function as a sum of sine and cosine functions. It is named after the French mathematician Joseph Fourier, who first introduced the concept in the 19th century.
2. How is a Fourier series summation calculated?
A Fourier series summation is calculated by using a formula that involves finding the coefficients of the sine and cosine functions that best fit the given periodic function. These coefficients can be determined using integration or other methods.
3. What is the purpose of using a Fourier series summation?
The purpose of using a Fourier series summation is to simplify the representation of a complex periodic function. It allows us to break down a function into simpler components and analyze its behavior more easily.
4. Can a Fourier series summation be used for non-periodic functions?
No, a Fourier series summation can only be used for periodic functions. However, there are other techniques, such as the Fourier transform, that can be used for non-periodic functions.
5. What are some real-world applications of Fourier series summation?
Fourier series summation has many practical applications, including signal processing, image compression, and solving differential equations. It is also used in fields such as physics, engineering, and economics to analyze periodic phenomena.
  • Math POTW for University Students
  • Differential Equations
