Homework Help: Fourier transform
  1. Feb 25, 2012 #1
    if y(ω) = F{x(t)}, what is F{y(t)} (F is the fourier transform operation)
    2. Relevant equations
    non
    3. The attempt at a solution
    I tried finding F^-1{y(ω)}, which is equal too x(t), but I could not go on with finding F{y(t)}
  3. Feb 25, 2012 #2
    I like Serena
    Hi homad2000! :smile:
    Check the section on "duality" on the wiki page: http://en.wikipedia.org/wiki/Fourier_transform
    It says what the transform is of a transform with the domain swapped.
  4. Feb 25, 2012 #3
    Ok, correct me if I'm wrong:
    I got F{y(t)} = x(-ω) ? or should I add the 2π to that?
  5. Feb 25, 2012 #4
    I like Serena
    Yep. That's it.
    Whether or not 2π should be added depends on the definition of your Fourier transform.
    As you can see on the wiki page, there are 3 different common definitions.
    Which of the 3 does your text book use?
  6. Feb 25, 2012 #5
    I believe i should add the 2 pi, because we use w = 2 * pi * f
    Thank you for your help, I appreciate it :)
  7. Feb 25, 2012 #6
    I like Serena
    That would not be the reason.
    Your Fourier transform would be defined as either:
    $$F(\omega)=\frac{1}{\sqrt{2 \pi}} \int_{-\infty}^{\infty} f(t) e^{-i \omega t}\, dt$$
    or
    $$F(\omega)=\int_{-\infty}^{\infty} f(t) e^{-i \omega t}\, dt$$
    In the first case you would not have a factor 2pi, while in the second case you would have a factor 2pi.
Loading...
