Fourier Transform
  1. Nov 10, 2015 #1
    1.
    Find the fourier series of :
    $$g(t)=\frac{t+4}{(t^2+8t+25)^2}$$
    2. I have been trying to write the function to match the formula $$\mathcal{F} [\frac{1}{1+t^2}] = \pi e^{-\mid(\omega)\mid}$$
    3.
    I have simplified the function to
    $$(t+4)(\frac{1}{9}(\frac{1}{1+\frac{(t+4)^2}{9}})^2)$$
    Cant really see where to go from here.
  3. Nov 10, 2015 #2
    Khashishi
    Try doing a partial fraction decomposition on g.
  4. Nov 10, 2015 #3
    I may be misleading you here but if you complete the square and then do a variable substitution you get what I would say is an easier problem.
  5. Nov 10, 2015 #4
    Ray Vickson
    You can write the Fourier transform as ##{\cal F}(g) (w) = \int_{-\infty}^{\infty} e^{-i w t} g(t) \, dt##, then apply integration by parts: ##\int u \, dv = uv - \int v \, du##, with ##u = e^{-iwt}## and ##dv = g(t) \, dt##. By a change-of-variables, the integral ##\int g\, dt## is do-able, and afterwards you will be left with a form in which your previous FT formula can now be used.
    BTW: you are NOT doing Fourier series, you are doing the Fourier transform. These two concepts are very different and should never be mixed up.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Fourier Transform
  1. Fourier transform (Replies: 4)
  2. Fourier transform (Replies: 1)
  3. Fourier transform (Replies: 1)
  4. Fourier transformation (Replies: 1)
Loading...
