Fourier’s Law of Conduction
  • Thread starter Bassalisk
Hello,
Can anybody explain to me how does this:
dQ=-X*dS*grad(T)*dt
t being time and T being TD temperature.
transforms into this:
Q=-X*S*(T2-T1)*delta(t)/d
delta(t) being time interval
d being thickness length of material
X being heat conductivity
Thanks
Answers and Replies
32
Maybe I don't quite get the form you have it in...S is what exactly?
S=Surface or Area
Is S area ?
The one dimensional form of the law is
[tex]\frac{{dQ}}{{dt}} = - kS\frac{{dT}}{{dx}}[/tex]
Where dQ/dt is the rate of heat flow which is directly proportional to the cross sectional area and the temperature gradient.
T is temperature
You only need use grad (T) for 3 D where grad(T) is the direction of max gradient.
t is time
S is area cross section
k is the constant of proportionality (thermal conductivity) -I don't like X because x is the axis variable.
You can integrate this if you assume the temperature fall to be a linear function of x through the material to obtain your second formula.
That is dT = ax and integrate between limits x =0 and x = thickness to eliminate constant of integration.
Thanks all, I got it now.
Related Threads on Fourier’s Law of Conduction
  • Last Post
