Fracturing Material: Why 2 Opposing Forces?
In summary, in order to separate an object, there must be at least two forces acting in opposite directions to create a torque and cause the object to break apart.
davon806
148
Hi,I have thought about this question for the whole night but I couldn't solve it.
I want to ask why we need at least 2 forces(they are in opposite direction) to separatre an object.
1 force or several forces act at the same direction could never divide an object.(but the object will accelerate)
Why?Can anyone explain in terms of forces acting on the substance?OK.Imagine you are in the outer space now,so that it is frictionless.
Is is possible to cause a fracture on an object if only a single force is acted on it?Assume the force is very large.Or the object will just accelerate but not break?
No, it is not possible to cause a fracture on an object with only a single force. This is because a single force can only cause the object to move, not to break apart. In order for an object to be separated, there must be two forces that act in opposite directions, which will create a torque or rotational force on the object, causing it to spin and eventually break apart. The two forces must also be of equal magnitude, or the object will just accelerate but not break.
1. What is fracturing material?
Fracturing material, also known as proppant, is a solid material used in hydraulic fracturing to keep the fractures open and allow oil and gas to flow to the surface.
2. What are the two opposing forces in fracturing material?
The two opposing forces in fracturing material are the force of the hydraulic pressure, which pushes the fractures open, and the force of gravity, which pulls the fractures closed.
3. Why are two opposing forces necessary in fracturing material?
Two opposing forces are necessary in fracturing material in order to create and maintain fractures in the rock formation. The hydraulic pressure pushes the fractures open, while the force of gravity helps to keep the fractures from closing completely.
4. What are the most commonly used materials for fracturing?
The most commonly used materials for fracturing are sand, ceramic beads, and resin-coated sand. These materials have the necessary properties to withstand the extreme pressure and temperature conditions in the oil and gas reservoirs.
5. What are the potential environmental impacts of fracturing material?
The potential environmental impacts of fracturing material include water and air pollution, seismic activity, and potential leakage of chemicals into the surrounding environment. Proper regulations and monitoring are necessary to mitigate these impacts and ensure the safety of the environment and surrounding communities.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
