Frame of Reference & Time: Defining Time Without a Ref.
In summary, a frame of reference is a coordinate chart that assigns a "time" coordinate to every event in spacetime, but this assignment has no physical meaning. Proper time, on the other hand, is the time actually measured by a clock traveling along a particular worldline and is independent of any choice of coordinates. The distinction between proper time and coordinate time can be obfuscated by the fact that the most convenient choice of coordinates often assigns a "time" coordinate that is the same as the reading on a clock carried by a reference observer. There is no general definition of time in physics, but relativity considers time to be just one aspect of spacetime. The number of dimensions and why there is only one time-like dimension is still unknown and
icantevenn
24
Hello,
I wish to know what is the relationship between a frame of reference and time. Specifically,without a frame of reference, what would be a hypothetical state of time. Professor Witten predicts that an ultimate physical theory will dissolve space-time as we know it. I would like to discuss how is time defined without a frame of reference.
The kind of "time" that is associated with a frame of reference (a better term would be "choice of coordinates") is more properly referred to as "coordinate time". A given coordinate chart assigns a "time" coordinate to every event in spacetime. But this assignment, of itself, has no physical meaning.
There is also "proper time", which is the time actually measured by a clock traveling along a particular worldline. This kind of time is independent of any choice of coordinates. Whenever you see an actual time measurement quoted--something like "1 year elapsed on observer A's clock between his departing from Earth and arriving at Alpha Centauri"--it is a proper time.
The distinction between proper time and coordinate time is often obfuscated by the fact that, for many problems, the most convenient choice of coordinates assigns a "time" coordinate to certain events that happens to be the same as the reading on a clock carried by a particular reference observer at those events. It's hard to be more precise unless you can give a specific scenario that illustrates whatever issue you are concerned about.
Suppose, for instance, that I wish to understand what exactly time is and wish to understand it by questioning beyond my surroundings. I imagine a space which is a vacuum, as much empty as possible. There are no objects, and for a moment I wish to remove my body's gravity from this thought experiment. What I am trying to understand is how time comes into existence.
You can define a concept called "proper time" easily enough - it's what your watch shows. No need to define a set of coordinates (a frame of reference) or anything. The problem is that you can't generalise that to work out "what time it is over there". It only tells you what time it is where you are.
You could set up a system of measurement of time at any point based entirely off people's watches and the speeds they were travelling, as long as you filled space with people and their watches traveling in all directions. But I think that, if you do that systematically, you end up defining a frame of reference.
You can handle specific problems without reference to a coordinate system - for example the twin paradox can be resolved simply using proper time and relative velocity. I am not sure about a general definition of time. I rather suspect any definition of "now, over there" implies a choice of frame.
Edit: Must type faster...
Yes, you put it perfectly. This is what would happen in almost all explanations.
I would like to ask you, based on everything that has been discovered in physics so far, how would you answer if I ask: how time comes into existence? For instance, gravity was action at a distance for Newton, but Einstein explained its source. Has there been any physical theory about time that says something similar?
I am not a physicist so my reading is limited. Thanks
Yes, it does.
Why do you think time must "come into existence"?
No, unless you consider relativity, which considers "time" to be just one particular aspect of spacetime, to be such a theory.
A number of physicists have expressed ideas that suggest that time sort of comes into existence at the Big Bang
It depends what you mean. In relativity, time is a dimension just like the three spatial dimensions. The only real difference between time and the spatial dimensions is that time has the opposite sign in the metric (i.e., Pythagoras' Theorem for space-time is ##\Delta s^2=\Delta x^2+\Delta y^2+\Delta z^2-(c\Delta t)^2##). That turns out to have a whole host of implications - notably that c is a speed limit for causation (which gets rid of all the "simultaneous causality" problems), and our very different experience of time versus space.
But, why four dimensions, not three or five? And why only one time-like dimension? As far as I'm aware we don't have a definitive answer to questions like this. I think that physicists largely assume that a future theory of quantum gravity will provide some kind of an explanation, but we're still working on that one.
Pop science articles, which is where I strongly suspect you read these ideas, are not science, and are not appropriate sources for discussion on PF. If you can find something in the peer-reviewed literature that discusses this idea, that would be within bounds.
Time is a part of space-time, which came into existence at the Big Bang as far as we're aware. What happens "outside the universe" or "before the universe" isn't something we have the tools to discuss, even assuming the concept makes any sense at all.
Edit: In fact, the Big Bang itself is a singularity, which means that relativity doesn't describe it - only shrugs its shoulders and says "you need a better theory to discuss what happens then". So it's another thing that we don't have an answer to.
Likes icantevenn
Thank you so much. This was very helpful.
1. What is a frame of reference?
A frame of reference is a set of coordinates and axes that are used to describe the position and motion of objects in space. It is an essential concept in physics and helps us understand how objects move relative to one another.
2. How does a frame of reference relate to time?
A frame of reference is important in defining time because it allows us to measure the duration of events and the rate of change in an object's position. Without a frame of reference, it would be impossible to accurately measure time.
3. Can time be defined without a frame of reference?
No, time cannot be defined without a frame of reference. Time is a relative concept, and its measurement depends on the observer's frame of reference. Therefore, a frame of reference is necessary to define time accurately.
4. How does Einstein's theory of relativity relate to frames of reference and time?
Einstein's theory of relativity states that time is not absolute and can vary depending on an observer's frame of reference. This means that two observers in different frames of reference may measure different times for the same event. Thus, frames of reference play a crucial role in understanding the concept of time in the theory of relativity.
5. How can we determine the most accurate frame of reference for measuring time?
The most accurate frame of reference for measuring time is the inertial frame of reference, which is a non-accelerating frame of reference. This is because it allows for the most precise measurements and is used as the standard for defining time in physics and other fields.
