Understanding the Franck-Hertz Experiment: Causes of Current Drop
In summary, the Franck-Hertz experiment involves bombarding mercury atoms with electrons and observing a sudden change in current when the electrons reach a specific threshold energy. This suggests that the mercury atoms can only accept energy at certain points, corresponding to a strong emission line in the ultraviolet spectrum at 254 nm. The sudden drops in current occur because the accelerated electrons with this energy are removed and cannot reach the collector plate.
Helphelphelp
Hi
In the FH experiment, what is physically happening when the excited mercury atom hits the metal plate? why does it induce a current drop?
Thank you for any help :)
Helphelphelp said:
Hi
The excited mercury atom does not hit any metal plate. They bombarded a mercury atom vapor with electrons, and showed that the electrons lost energy only at discrete levels (corresponding to the energy needed to exite the mercury atoms). See this (pretty good) wikipedia article:
https://en.m.wikipedia.org/wiki/Franck–Hertz_experiment
In the FH experiment the electrons flow under a potential difference. In passing through the tube it encounters Mercury atoms and collide with them- initially as the PD is increased current grows but there is a sudden change at particular voltage .
The sudden change in current suggests that the mercury atoms cannot accept energy until it reaches the threshold for transferring mercury to an excited state.
And this happens only at certain voltage
This happens at say 4.9 volt excited state of Hg atoms and corresponds to a strong emission line in the ultraviolet region of spectrum of mercury at 254 nm .
The electron's energy is being absorbed in a packet corresponding to this value.
Drops in the current occur since an accelerated electron which has 4.9 eV of energy gets removed and can not reach the collector plate.
Likes Helphelphelp
1. What is the Franck-Hertz experiment?
The Franck-Hertz experiment is a classic physics experiment that demonstrates the energy quantization of atoms. It involves passing electrons through a tube filled with a low-pressure gas and measuring the current as the electrons are accelerated by a voltage. The current drops at specific voltages, indicating that the electrons are losing energy and exciting the gas atoms.
2. What causes the current drop in the Franck-Hertz experiment?
The current drop in the Franck-Hertz experiment is caused by inelastic collisions between the electrons and the gas atoms. When the electrons have enough energy, they can excite the gas atoms to higher energy levels. This results in a decrease in the number of electrons that can reach the anode, causing a drop in current.
3. What is the significance of the current drop in the Franck-Hertz experiment?
The current drop in the Franck-Hertz experiment is significant because it provides evidence for the quantization of energy in atoms. This experiment helped to confirm the Bohr model of the atom and the concept of discrete energy levels. It also paved the way for further research into quantum mechanics and the understanding of atomic structure.
4. How does the voltage affect the current in the Franck-Hertz experiment?
The voltage in the Franck-Hertz experiment affects the current by accelerating the electrons towards the anode. As the voltage increases, the electrons gain more energy and are able to excite the gas atoms to higher energy levels. This results in the current dropping at specific voltages corresponding to the energy difference between the different energy levels of the gas atoms.
5. What other factors can affect the current in the Franck-Hertz experiment?
Aside from voltage, other factors that can affect the current in the Franck-Hertz experiment include the type of gas used, the pressure of the gas, and the distance between the cathode and anode. These variables can alter the energy levels of the gas atoms and therefore affect the energy required for the electrons to excite them. Additionally, the temperature of the gas and the presence of impurities can also impact the current drop in the experiment.
  • Quantum Physics
  • Other Physics Topics
