Homework Help: Free Body Diragram of a pulley
  1. Feb 21, 2015 #1
    In the figure (Figure 1) each of the suspended blocks has weight w. The pulleys are frictionless and the ropes have negligible weight.
    2. Relevant equations
    w = mg
    Forces cancel out, so Tension = weight (since they are suspended)
    3. The attempt at a solution
    For a (pulley) ), I tried a free-body diagram with mg pointing down, and tension pointing up, with equal magnitude. This was marked wrong, but I don't see any other forces acting on the weight.
    For b (either weight) ), I did the same thing as I did in a, because, after all, isn't it just mg and tension that act on both weights?
    For c (either weight) ), same as a and b.
  3. Feb 21, 2015 #2
    Nathanael
    Exactly what does the problem ask? To draw a free body diagram of the pulley? If so then why did you draw FBDs of the weights?
  4. Feb 21, 2015 #3
    For part A, it's of the pulley system. B and C ask you to draw for one of the weights.
  5. Feb 21, 2015 #4
    Nathanael
    Did you get B and C right? For A you described an FBD for the weight, not the pulley.
  6. Feb 21, 2015 #5
    No, B and C are wrong as well :( That's why I don't understand, I would have thought it would just be tension and mg...
  7. Feb 21, 2015 #6
    Nathanael
    Your teacher didn't explain why you got it wrong? I would ask him/her why you got B and C wrong. Do you know why you get A wrong?
    Do you have the exact problem statement?
  8. Feb 21, 2015 #7
    That is the exact problem statement. :(
    In the case (a), draw the free-body diagram.
    In the case (b), draw the free-body diagram of one of the blocks.
    In the case (c), draw the free-body diagram of one of the blocks.
    Word for word.
    And this is one of those online assignments. I can't get any teacher feedback until the week begins.
    The problem itself doesn't say whether it's wanting the pulley or the weight. But given that I've tried tension up, mg down, and that's incorrect, and I believe that to be the correct FBD for a suspended weight, I'm led to believe that it's asking for the pulley system...
Have something to add?
Draft saved Draft deleted
