Free convection heat transfer
In summary, the conversation discussed the value of 37 for h in convection heat transfer and whether it is considered free or natural convection. It was mentioned that free convection is driven by differential density due to temperature differences in a fluid, while forced convection is driven by external means such as a fan. The estimated heat transfer coefficient for natural convection was given as 10w/m^2-k, while the range for forced convection is larger, but a value of 25w/m^2-k can be used for a rough estimate. It was also noted that these values may vary depending on factors such as fluid properties, geometry, and ambient conditions.
3wash
Dear all
I got a value of 37 for h ( convection heat transfer )
Does it consider as free or natural convection heat transfer coefficient?
Thanks in advance !
And Sorry its not a Homework problem :)
What is the application. English or SI units. More information would be helpful.
Your question is difficult to answer without more informtation, but as a general rule free convection is driven by differential density due temperature difference in a fluid and forced convection is driven by some external means (for example a fan).
For nature convection heat transfer coefficient h =10w/m^2-k(including radiation)
For force convection, h range is more large, however you can take 25w/m^2-k for coarse estimate.
Where exactly do these estimates come from? Without citing a source they're gibbereish and can't be used; especially since they don't take into account anything regarding fluid properties, geometry, etc.
Thanks for Mech's remind. The listed value is for air cooling.
Acctually the precise h value needs detailed information such as shape, fluid, ambient condition. Normally i use CFD software to calculate.
However, the listed value can be used for draft esimated and may answer the raised question.
1. What is free convection heat transfer?
Free convection heat transfer is a type of heat transfer that occurs when a fluid, such as air or water, is in contact with a solid surface and the motion of the fluid is caused by natural buoyancy forces. This type of heat transfer is driven by differences in temperature and density within the fluid.
2. How is free convection heat transfer different from forced convection heat transfer?
Free convection heat transfer is different from forced convection heat transfer in that it does not require any external force or energy to move the fluid. In forced convection heat transfer, an external force, such as a fan or pump, is used to move the fluid and enhance heat transfer.
3. What factors affect free convection heat transfer?
The rate of free convection heat transfer is influenced by several factors, including the temperature difference between the solid surface and the fluid, the properties of the fluid (such as density and viscosity), the geometry and orientation of the solid surface, and the presence of any obstacles or barriers in the fluid flow.
4. How is free convection heat transfer calculated?
The rate of free convection heat transfer can be calculated using mathematical equations, such as the Nusselt number correlation or the Grashof number correlation. These equations take into account the relevant parameters, such as temperature, fluid properties, and surface geometry, to determine the heat transfer rate.
5. What are some real-world applications of free convection heat transfer?
Free convection heat transfer is a fundamental process that occurs in many everyday situations. Some examples include the cooling of a hot cup of coffee, the heating of a room by a radiator, and the transfer of heat from a computer's processor to its heat sink. It is also important in industrial processes, such as cooling towers and heat exchangers.
  • Mechanical Engineering
  • Materials and Chemical Engineering
