Free energy?
  1. Jul 12, 2008 #1
    free energy??
    water disasotiates to H+ and 0H-
    if you could take the dissasociated ions away, and combine them how much energy could you get out?
    In the liquid remaining, more would dissosciate, and the process could be continued.
    Where does this energy come from - it sounds like free energy which cant be the case?
  3. Jul 12, 2008 #2
    Re: free energy??
    it takes energy to break the bonds and gives energy out to make them. therefore it isn't "free energy".
    dont have an energy table on me but if you look up exothermic reactions on google, you should find what you are after
  4. Jul 13, 2008 #3
    Re: free energy??
    It takes energy but where does the energy for this dissociation come from.
    Im wondering if it comes from the heat withing the liquid - if so possibly removing the ions would allow more to remain dissociated and possibly lower the temp of the liquid
  5. Jul 13, 2008 #4
    russ_watters
    Staff: Mentor
    Re: free energy??
    The usual way is to apply an electric current to the water to disassociate it to H2 and O2.
    No, it has to be external. Conservation of energy applies.
  6. Jul 13, 2008 #5
    Andy Resnick
    Education Advisor
    Re: free energy??
    The energy you get out, from the ions re-combining, is equal (at best) to the energy required to seperate them in the first place.
    Water normally has 10^-7 mol H+ and 10^-7 mol OH-. (If that's the correct unit.. molar concentration is what I'm going for) But, those ions don't preferentially separate in space unless you (the experimenter) apply an electric field. Once you put some energy into the water to seperate the charges, you can get that energy back by allowing the charges to move.
  7. Jul 23, 2008 #6
    Re: free energy??
    I was just wondering, if we have an infrared to electric converter, that is it converts infrared energy to electric energy, then we can get "free energy". Everything around us radiates infrared radiation. We will never run out of infrared radiation. So we can keep converting the infrared energy to other forms of useful energy.
  8. Jul 23, 2008 #7
    Re: free energy??
    Waste of time.
    Solar.
    Wind.
    Geothermal.
    Wave.
    Installation costs are not free.
    Operating costs are not free.
    Some human labor and oversight required.
  9. Jul 23, 2008 #8
    Re: free energy??
    yes, and it is the future of solar cells
    you could probably find somthing on google under "spray on solar cell"
    it could be worn on clothes to recharge batteries, put on houses, cars, pretty much anywhere that is exposed to sunlight (this is theoretically speaking of course). It may mean hydrogen cars that never need to be recharged/refuled, etc.
    it would be most useful for the army, who could use their equipment and recharge it anywhere during the day, even in the clowdy days.
    one day - but it would be expensive. take 100 years or so to refine i am guessing.
    may not be that much point in the end though, depends. but might as well move forward
  10. Jul 23, 2008 #9
    Re: free energy??
    The laws of thermodynamics say no, which is the well known reason why we can't power ships by the abundant (local) thermal energy of the ocean (leaving wakes of ice). It is why refrigerators consume electricity. Your "infrared converter" will emit just as much black-body radiation as it absorbs.
    Solar panels only work because most of the sky is dark (and hence the panel itself stays relatively cold); if the sun encompassed the whole sky then we would come into thermal equilibrium with the sunlight, and despite there being "more energy present" it would be entropically impossible to harness any of it to do work.
  11. Jul 23, 2008 #10
    Re: free energy??
    If you say its impossible, why then do I know of several universities that are trying to pursue it?
    http://news.nationalgeographic.com/news/2005/01/0114_050114_solarplastic.html
  12. Jul 24, 2008 #11
    Re: free energy??
    Even though IR is 'all around us', the intensity is extremely low. The issue is intensity when trying to usefully harness it. That is why , as kateman has pointed out, it is the solar IR that is being exploited....since its intensity is high. ...However, the main issue is still cost per watt.
    Can the material be economically produced? If so it will be a great boost to solar 'cell' efficiency.
  13. Jul 24, 2008 #12
    Re: free energy??
    It is impossible for ambient temperature devices to extract work from the black-body radiations of everything else that is at the same ambient temperature. This is not to say that it isn't possible for ambient temperature devices to extract work from any given components of the black-body radiations of something that is above ambient temperature (particularly the IR component of sunlight). I doubt you will find many scientific journal papers seriously advocating the extraction of work from the IR emissions of things that are just slightly different to ambient temperature (like people, or machines, or the night sky) because (since the available energy and Carnot efficiency are just so low) it is far more effective to harness sunlight. Learn thermodynamics and be critical of what you read.
  14. Jul 24, 2008 #13
    russ_watters
    Staff: Mentor
    Re: free energy??
    Even if you could extract energy from a small delta-T via infrared radiation, the energy density is so low it wouldn't be worth it. Solar panels get probably a thousand times more energy from the sun's spectrum and their energy per unit area is still too low to be economical. Why buy a square meter solar panel that produces 1 watt of power?
  15. Jul 24, 2008 #14
    Re: free energy??
    very interesting, thank you
  16. Jul 24, 2008 #15
    russ_watters
    Staff: Mentor
    Re: free energy??
    Oops, I forgot - the device you guys are describing already exists. http://en.wikipedia.org/wiki/Radioisotope_thermoelectric_generator
    They are used to power space probes, which radiate against the black coldness of space (using nuclear decay to generate the heat). People are also trying to sell them to paste onto truck exhaust pipes. The efficiency is too low to be worth the money for even that application (where you do have a decent delta-T), though in that application, they capture the heat by conduction and dissipate it by convection.
    The efficiency is still pretty low - perhaps if it gets better it could become viable for higher delta-T waste-heat generators.
  17. Jul 24, 2008 #16
    Re: free energy??
    Pardon my ignorance,
    Is a photovoltaic cell an ambient temperature device?
    Is photoelectric effect an ambient temperature effect?
    If they are not, then they maybe we can extract work from black-body radiations.
    The problem with harnessing sunlight energy is that sometimes there is no sunlight!
    Whereas infrared is in abundance and always there.
    So even if the efficiency is restricted by Carnot efficiency, we can still achieve 1 to 2% efficiency. And this 1 to 2% of a large amount of infrared radiation can translate into a very high W.
  18. Jul 24, 2008 #17
    russ_watters
    Staff: Mentor
    Re: free energy??
    They run hotter than ambient due to the absorption of infrared.
    That question has no meaning that I can see. If you are asking if a photovotaic cell will be at ambient temperature if there is no sunlight, the answer is yes. As a result, there is very little incident radiation of any kind.
    Ever-present, yes. Abundant, no. There is more energy to be had in capturing the ambient lighting in a room than there is in capturing the radiant heat from the people in it.
    There is not "a large amount of infrared radiation".
    A human being dissipates about 70W of energy at rest. Of that, about 60% is in the form of radiation for a naked person in a dark room. Capturing those 42 watts would require wrapping your body in about 2 square meters of collector, for an energy density of 21 Watts per square meter. Incident radiation from the sun is over 1000 W/m^2.
  19. Jul 26, 2008 #18
    Re: free energy??
    I think infrared radiation is currently underestimated.
    I read somewhere that half of the sun radiation is infrared radiation.
    Furthermore, if a body dissipates 70W, then 10 bodies will dissipate 700W.
    If we focus the energy, like using a lens, we can increase the Watts per square meter.
    Using a fresnel lens, we can focus 1 m2 into 1 cm2. Thats 10000 times more powerful!
    So even with 21 W/m2, it becomes 21 x 10000 W/m2!
  20. Jul 26, 2008 #19
    Dale
    Staff: Mentor
    Re: free energy??
    Hi Sam,
    Infrared radiation is not underestimated. You seem to think that the physical principles involved are somehow not well understood, but that is not the case this is very well understood.
    Have a look at the http://en.wikipedia.org/wiki/Stefan-Boltzmann_law" [Broken]. Even if you had a perfectly effecient IR converter that was somehow magically kept at absolute zero, the incident IR energy is less than 0.5 kW/m² even on a hot summer day. Now, let's say that instead of absolute zero we are only going to keep your IR absorber 10º cooler than ambient and lets say that you had a really good 50% efficiency, that brings you down to about 15 W/m² even on a hot summer day.
    As any homeowner can tell you, it takes a lot more than 15 W/m² to cool something down 10º below ambient. There is just nothing to be gained this way, TANSTAAFL.
  21. Jul 26, 2008 #20
    russ_watters
    Staff: Mentor
    Re: free energy??
    It isn't.
    That's true, but what you suggested was getting ir radiation from objects around us, not from the sun.
    And all you have to do is line all the walls, ceiling, and floors of a building with lenses! That's just not realistic.
