Unravelling the Mystery of Free Energy
In summary: It's not free, and it's not energy from nowhere. It just happens to be a convenient way to get energy from the sun.In summary, the water disassociation process results in the release of energy. This energy can be harnessed by using an electric current to separate the ions, or by wearing a "spray-on solar cell" that absorbs and re-radiates the energy. The process is not free, and it will require some human labor and oversight in order to be successful.
  • #71
uart said:
Ok Sam, let's do some rough calculations based on these figures.
When we use a lens to focus light from an object then the best focus we can obtain gives an image of the object with a size ratio of Image Size / Object Size = Image Distance / Object Distance, with distances measured from the lens. This is becasue an object at any finite distance has rays that are not parallel but diverging (I'm pretty sure you were already taking this into account).
So if we want for example a one cm diameter image of the Sun then the required focal length can be calculated from the thin lens formula, 1/I + 1/O = 1/F, where I and O are the image and object distances and F the focal length. This formula can be re-arranged to give the image linear scale factor of I/O = F/(O-F), which for the case of the Sun we may assume O>>F and hence,
[tex] \frac{Image Linear Size}{Oject Linear Size} \simeq \frac{F}{O}[/tex]
So returning to the desired one cm diameter image we see that the required focal length (maximum) is F = Sun Distance * 1cm / Sun Diameter, which using numerical values gives F is about 1.07 meters. This is the maximum focal length to achieve a 1 cm image, with a shorter focal length we can certainly focus an even smaller image of the Sun.
Heres the problem though. If we stick with a one meter focal length then we can make the lens a fairly large diameter without requiring the light to be bent more than physically possible by the lens (there is a limit because as we go for higher refractive index in order to bend the light more we also run up against the problem of total internal reflection in the lens). If however we go for a short focal length then we can make the image smaller but the diameter of the lens will also have to be smaller to avoid needing to bend the light more than physically possible. In other words we can't really gain anything by going for a smaller image and a shorter focal length.
Ok so let's stick with a 1cm image and a 1m focal length for now. Let's assume we can achieve a focal length about the same as the lens diameter. This will give the lens an area of Pi/4 or about 0.8 m^2. By your figures we can collect about 800 Watts of power over this area. Let's assume 100% of that 800 Watts makes it to our 1cm^2 cavity and is 100% absorbed and the cavity has no thermal conduction losses and the "shiny" part has zero emissivity, that's about as favourable assumptions as we can make ok.
If the cavity did reach a temperature of 6300k then the radiation loss from the cavity would be sigma * T^4 * A = 5.67E-8 * 6300^4 * 1E-4 which is about 9000 Watts leaving our cavity. But by our most optimistic calculations the inflowing energy is only 800 Watts, it doesn't take much effort to workout which way the energy is flowing!
Now you could argue that we could overcome this problem by having a lens with a diameter very much bigger than it's focal length (diameter about 11 times the focal length) but I'm almost certain an optics guru (not my area) could prove that impossible. It certainly seems unlikely to me, I'm pretty sure that total internal reflection in the lens would ruin it even if a material with refractive index high enough to bend the light that much were available. (You'd be looking at bending the light through about 85 degrees!)
Great effort.
My gut feel is that the 1 meter lens diameter (800W) will not provide enough energy to bring something all the way up to 6300K. The scale is off. It should be more fruitful to look at something much bigger, like 100 meters!
Working backwards, in order to receive 9000W, we need to collect the sun's rays from an area of 9 m2 (1kW/m2). Hence we need a lens diameter of 3.4m or more(not 11 times bigger but square root of 11 times bigger). It doesn't look too daunting after all.
Let's check whether such a lens is possible (diameter 3.4m, focal length 1.07m, refractive index 2.4). The power of a thin lens, P = (nlens - no)/no x (1/R1 -1/R2), and the focal length is the inverse of P.
A lens with R1 = 3m and R2 = -3m does give a focal length of 1.07m.
In any case, if lens is a problem, then we can use other means of focusing the sun's ray such as using mirrors or mirrors in combination with lens, (or maybe even gravity to bend and focus light).
Using mirrors, we can bring together square kilometers of sun's radiation to the body in question. This is being used in some solar projects.
  • #72
If all we are doing is concentrating the sun's rays to send them to a solar panel, why do we care if we get 6300K anyway?
  • #73
Count Iblis, I was trying to follow your reply.
It went on quite well in the beginning but it was difficult to link the end and the beginning together.
While the total energy in a system is constant, the amount of energy that can be extracted from it to do useful work is dependent on the temperature, right?
  • #74
The amount of energy being extracted depends on temperature, yes. But in a solar cell, efficiency goes down as temperature goes up. If you use a collector to drive a thermodynamic cycle (a steam cycle), efficiency goes up as temperature goes up. But there is a practical limit of perhaps 500 K.
  • #75
The square kilometers of mirrors you refer to do not even attempt to focus the energy down to a 1 cm target. As russ mentions, there is no benefit in focusing the energy that tightly so it isn't done. I am not at all convinced that is possible, and your handwaving argument certainly doesn't demonstrate that.
In any case, solar power with mirrors is already being done, so there is nothing new about this.
  • #76
That's right. In this case the efficiency is worse than in case of an ideal Carnot process, basically because of entropy production when the emited photons by the blackbody are replenished.
  • #77
Sam Lee said:
Great effort.
Yep I made a simple mistake and forgot to square-root it. You really think a focal length less then one third the lens diameter is easy?
Firstly a 3.4 meter diameter lens with a radius of curvature 3 meters is hardly a "thin lens", make a drawing and do the maths, it's over a meter thick!. You have to be joking, the critical angle (beyond which you get total internal reflection) is only 23.5 degrees with n=2.5!
Draw a ray diagram and show how all the rays from the entire surface of that lens can be focused to one cm without any rays exiting at more than 23.5 degree from the normal. It's impossible, your proposed lens absolutely will NOT work.
  • #78
Not only that, but the 1m focal distance would be inside the lens!
You will be better off with mirrors since you don't need to worry about refractive index, but I think you will ultimately hit similar geometric limitations.
  • #79
You are absolutely right.
Forget about lens. No wonder big solar projects use mirrors to heat up a body.
Now we can really scale things up.
We can have a 100m parabolic dish and focus all the energy to a spot.
Anyone knows how to work out the maths?
  • #80
This body (6300K) that we are talking about could be a thermal stroage body.
It is not a solar cell.
Solar cells are more efficient if they receive radiation from bodies with higher temperatures.
  • #81
You want to use thermal storage to hold energy to later pass to a solar cell? Why?
  • #82
I agree with russ. Even assuming that you can achieve sufficient focusing (I am still skeptical) this is a really bad way to store energy. The material engineering challenges of handling and insulating a 6kK object are not even worth considering.
The discussion about lenses and 6kK objects has merely been to demonstrate the applicability of the 2nd law to optical systems, i.e. to demonstrate that you cannot focus sufficient energy to cause heat to radiate from a colder body to a hotter one.
  • #83
My understanding was that the question of focusing the sun to produce a temperature hotter than the sun came about as a result of Sams desire to focus normal background IR radiation to get hotter than ambient temperature suitable for useful energy conversion. People were saying it was impossible so Sam brought up the example of using a lens to focus the Sun to such high temperatures as an example (now debunked, at least for the lens) of why it could work.
I'd like to see some argument of why a parabolic mirror would also suffer from some similar limitaion to the lens so we could finally put this to rest.
  • #84
Again, it's the second law of thermodynamics:
Heat cannot spontaneously flow from a material at lower temperature to a material at higher temperature.
It's similar to the principle of pressure, where you have a large vessel and a small vessel sitting next to each other, both partially with water to the same level. The vessels are connected at the bottom. The downward force of the water in the larger vessel is much, higher than the downward force of the water in the smaller vessel. Does the water flow from the larger vessel to the smaller one?
  • #85
Yes obviously I know that, and that's why I know it would be impossible. I'm saying that it would be interesting to see a specific physical or technological limitation in the case of the mirror.
  • #86
The issue was discussed in J Phys D in 1992-1993. S. Panse ("Non-spontaneous radiative heat transfer," J. Phys. D: Appl. Phys. 25 (1992) 28-31) argued that exceptions to the Second Law could occur in some optical systems similar to the one Sam Lee is proposing. In a rebuttal article, K.M. Browne ("Focused radiation, the second law of thermodynamics and temperature measurements," J. Phys. D: Appl. Phys. 26 (1993) 16-19) showed that in fact the Second Law was not violated in these systems because the finite size of the radiating body prevented focusing its rays to a point. (DaleSpam was right to request a ray diagram for these types of focusing proposals!) Browne concluded that the Second Law could also be expressed as: "No system may focus from one object, through an aperture onto a second identical object, more radiation than may be emitted by the second object through the same aperture."
When someone proposes a violation of the Second Law, it's easiest to infer the Law as a rebuttal. It's harder (but perhaps more satisfying) to show specifically why the idea won't work. Browne does an admirable job in the article mentioned above.
  • #87
Where can we find the articles online?
Any web sites?
  • #88
K.M. Browne ("Focused radiation, the Second Law of Thermodynamics and temperature measurements," J. Phys. D: Appl. Phys. 26 (1993) 16-19) showed that in fact the Second Law was not violated in these systems because the finite size of the radiating body prevented focusing its rays to a point.
Yes that is exactly along the lines I was thinking (similar to the situation with the lens) except I'm not so familiar with the detail of a parabolic mirror when used with diverging light rays so I wasn't sure how to prove it. Perhaps some time I'll be able to look up that reference, thanks Mapes.
  • #89
I have read this thread with interest because I face exactly the problem being discussed.
I have devised a device to focus RANDOM ambient Radiant Energy (RE) to an area smaller (19.63 sq mm) than the collection area (153.94 sq mm).
The first part of the device redirects the input RE that falls on a circle (180̊) and outputs it in the format of a cone with an internal angle of 30̊. This part has been built and tested
I still don’t know what will happen when I bombard the final target at 300K with photons also at 300K (in a black body distribution curve).
Using the Stephan Boltzmann formula we can calculate the optimal energy radiated into the collection area as 7.07 joules but in the real world we may have an emitter with emissivity of 0.9 and a net efficiency of 80% giving us 5.09 joules.
Provided the emitter emits the calculated amount of energy and provided the target will absorb all the photons, if we concentrate all this energy and have it absorbed by the target then the temperature of the target should rise to 482K.
It has been suggested to me that the emitter will not emit because it is at ambient. I don’t buy this. My understanding is that all surfaces above 0K will output RE - the amount dictated by the temperature and emissivity of the surface.
Remembering that a radiation distribution at a particular temperature will have some photons at higher and some at lower temperatures, I have difficulty understanding the absorption of the photons. I am lead to believe by some that photons that do not have sufficient energy to bump an electron up a level will simply pass through the object. I have difficulty with this because if this were the case then all the lower temperature photons would never be absorbed and we would end up in a sea of lower and lower temperature photons. This would cause the ambient temperature to decline as fewer photons of sufficient temperature would be emitted in the system. Furthermore, these low temperature photons would simply pass through all the matter and exit the system.
It makes more sense to me that the photons are absorbed. If they do not have enough energy to bump the electron up to the next level then they presumably will add to the energy content of the electron in some way. Another subsequent photon might cause the electron to have enough energy to bump it up a level.
My calculations may be flawed and please correct me if I am wrong but to me the amounts of energy involved are HUGE and not as small as some have indicated in this thread. Remember that the amount of energy is calculated from the temperature rise above absolute zero. For example: Energy emitted from 1 sq m of black body at 300K = 45,927 joules or 62 horse power. This figure will decline based on efficiencies of the system used to collect the energy.
This is nearly 46 times as much energy than that which arrives from the sun at noon at the equator on a clear day which is generally accepted as being 1000 joules.
Furthermore considering that this energy is emitted 24/7 and not only during sunny daylight hours, there is an immense storage of energy waiting to be tapped. The capture and storage of this energy is a tantalizing target.
  • #90
It looks like you're claiming that an arrangement of mirrors near two 300K objects will heat one of them to 482K. This is not going to happen; it would violate the Second Law. Kip Browne's paper (which I cite above) discusses these types of focusing systems and shows how to correctly quantify what's irradiating what. I recommend taking a look at it.
Check that math again!
  • #91
A impressively quick reply!
I have read K. Browne’s paper and in a nut shell he shows that for the two geometries studied, the target had a larger surface area than the sending object. Consequently the targets emitted all that they received from the emitter without raising their temperatures. My design is different in that the target is smaller than the emitter and so will receive a concentration of photons as envisaged by Sudhir Panse. Browne does not cover this eventuality even though he says that other geometries may be found, This is why I am still pursing it. Unless I learn something new that explains why it shouldn’t work, I will continue making the device. I expect to complete the device in the next 2 months when all my questions will be answered. If it doesn't work I shall still be looking for answers LOL
I have often heard the answer that the second law of thermodynamics says it can’t be done. People who say this have been unable to tell me why it won’t work or have some spurious illogical answer. There may well be a reason deep down in the realm of quantum mechanics why it won’t work but I have not heard it yet.
I suggest that the second law of thermodynamics was created from 300 or so years of empirical observation and is not tied to any mathematical proof. This leaves it open to future findings.
Your suggestions are welcome and may save me a great deal of work and expense.
As I said, my math may be wrong but here goes :
I used this site to compute the energy collected at the emitter :
http://hyperphysics.phy-astr.gsu.edu/Hbase/thermo/stefan.html#c3
As I only want the energy emitted, not the net difference between two bodies, I used a T cold of 0K and a T hot of 300K with a collector area of 153.94 sq mm
(oops found my error - I put in 153.94 sq cm not 153.94 sq mm)
Collector collects 0.0707037 watts
I would need 1,000,000 / 153.94 collectors to get 1 sq m = 6,496.12 collectors
# of collectors * watts per collector = 0.0707037 * 6,496.12 = 459.27 watts or 0.62 HP
That certainly looks more reasonable, thanks for the pointer.
At this (now corrected ) rate it looks like the emitted energy is just under half that of the solar energy per unit area. The difference however is that radiant energy runs 24/7 and is not reliant on latitude or cloud cover and so is still a very attractive goal.
  • #92
It is trivially easy to prove that this idea of yours is false - anyone who owns a telescope could point it at a wall and expect to be able to burn a hole in a piece of paper!
  • #93
You are correct. The telescope won’t burn a hole in a piece of paper. That is simply because the telescope would not focus ALL the radiant energy from the wall, only those minuscule small number of rays that travel in a parallel manner towards the telescope.
I like your site and am particularly impressed with the Hubble image.
  • #94
Isn't this a problem? I have to admit I don't follow all of the arguments above, but think about what is keeping your emitter at the temperature of 300K. Isn't it just all of the 'random' radiant energy bouncing around between the emitter and its surroundings?
  • #95
Unless the telescope is right up against the wall, the amount of radiation that is not parallel will be miniscule! Besides - even if it misses a quarter or half the radiation, it can still focus light to thousands of times the intensity with which it was emitted: looking at a wall with a telescope as big as mine would be painful to your eyes.
Thanks!
  • #96
Anyway, sorry, but this discussion is explicitly against forum guidelines. We deal only in established science here.
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Electromagnetism
