Free fall due to gravity
  • Thread starter Pete69
I was given a problem to solve for the speed of a body falling under gravity [equation (1)] where g is acceleration due to gravity, which was easy enough.. but then i thought i would extend it to the case where g is non-constant, and so arrived at equation (2), (where where z is the height above earth [z'=dz/dt and z=dv/dt and z^-2 means z to power -2], and M is the mass of the earth and G is the gravitational constant)
(1) : dv/dt = - g - kv
(2) : z'' + kz' + GMz^-2 = 0
I believe this is a non-linear second order DE?? i attempted to solve by setting
z'' + kz' = 0
and solving the complimentary equation, which was OK, but when i came to solve for the particular integral
z'' + kz' = -GMz^-2
i ran into problems, as after substituting in the D and Q operators (http://silmaril.math.sci.qut.edu.au/~gustafso/mab112/topic12/ [Broken]), i could not use the First Shift Theorem, as the RHS is not in an exponential form...
Any ideas anyone?
Answers and Replies
Tom Mattson
Staff Emeritus
Yes, but rather than get into that let's look at your first order equation for [itex]v[/itex].
Do the following.
1.) Show that [itex]\frac{dv}{dt}=v\frac{dv}{dz}[/itex].
2.) Insert [itex]g=\frac{GM}{z^2}[/itex] into the equation.
3.) Find an integrating factor that makes this equation exact (it can be done).
4.) Solve.
HallsofIvy
41,833
956
z'' + kz' = 0
There is no "complementary equation" nor is there a "particular integral". Those are both concepts in linear differential equations where the non-homogeneous part is a function of the independent variable only.
z'' + kz' = -GMz^-2
Any ideas anyone?
Related Threads on Free fall due to gravity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
28K
