Free Fall Equations: Velocity and Air Resistance Effects Explained
In summary, the equation of motion for a particle of mass m falling from rest from a height h above the ground, with a retarding force per unit mass of kv^2, can be expressed as F=mg-mkv^2. To find the velocity at which the particle reaches the ground, the equation v^2=u^2+2ah can be used, where u is the initial velocity and a is the acceleration. However, this equation is only valid when there is constant acceleration, which is not the case here. Instead, the concept of terminal velocity can be used, where the force due to gravity is equal to the air resistance, given by kv^2. Therefore, the velocity at which the particle reaches the ground
Vandella
25
A particle of mass m falls from rest from height h above the ground. The retarding force per unit mass due to air resistance is kv^2 where k is a constant and v is the velocity of the particle
a) write and simplify the equation of motion for the particle
b) find an expression for the velocity with which the particle reaches the ground
c) if h is very large, determine the expression for the velocity of the particle
d) explain what happens to the velocity when h is very large
a) i thought a particle falls with equation F=ma and the air resistance works against this so F=ma-kv^2
b) no idea just yet :(
c) when h is very large there is an equilibrium in net force and so terminal velocity is reached
terminal velocity = √2mg/pA(cd)
where p=density A=area of object cd=drag coefficient m=mass g=gravity
d) pretty much covered in part c) an object stops accelerating because the force of gravity and the air resistance are in equilibrium
re (a):
First draw a FBD for the paraticle.
What will be the net force downwards?
the net force acting on the particle would be mass x gravity?
How many forces act on the particle?
gravity is acting downwards air resistance is working against gravity?
Exactly. So the net force downwards is ...
net force = g-kv^2 ?
hence retarding force is mkv^2.
therefore net force downwards is Fnet = mg - mkv^2.
ahh i get it now :)
so part b would use the equation v^2=u^2=2gh where v = final velocity and u = initial velocity so therefore final velocity v=root (2gh)
sorry i meant v^2=u^2+2gh
Nope. This equation is only valid when you have constant acceleration. The acceleration here is not constant, because the force is not constant.
Just as i think i am getting somewhere :)
back to my notes it is then
acceleration is not g because g is for FREE FALL and here the falling is not freely but there is a dragging force. Instead of g you have to use the acc that you find from Fnet = ma
That is the reason why you were asked to do part (a).
No. See my previous post. This entire equation is invalid because the acceleration is not a constant.
To the original poster: I would encourage you to look into the concept of terminal velocity. Hint: what happens when the velocity becomes large enough that kv2 = g ?
Yes cepheid is correct.
v^2 = u^2 + 2ah holds only constant acc and here the acc is not constant. Forgive my mistake!
I think that one has to integrate the acc eqn to get v.
arghh more integration :(
so acceleration = dv/dt
and then substitute into v-u=ah ?
ohh and thanks a lot for all your help
No integration is required to solve part b. :smile:
Actually, I just looked at parts c and d, and it seems like they refer to the terminal velocity case, whereas part b wants a general solution. If that's true, then you have a non-linear differential equation to solve. Uh, good luck with that.
no integration needed is the best news i have heard for a while :)
i have looked at terminal velocity and think i am getting somewhere with that
terminal velocity is reached when force due to gravity = air resistance
mg=kv^2
air resistance can be written as 1/2 (drag coefficient x density x frontal area x velocity^2)
mg=1/2 (dc p Af V^2)
then its simply manipulating for velocity (just about the only part I can do :)
as for part b) more time looking at my scribbled notes is required
mg=kv^2
None of this stuff in red is really necessary. For this problem, you're given the drag force. It's kv2. So, all these pesky constants like the density and drag coeff. etc are just absorbed into k. You really only need to give your answer in terms of k.
So for part c, terminal velocity, it's literally just: g = kv2. Solve for v.
I can help you set up the differential equation, but I can't help you solve it. To set up the differential equation, start with the equation of motion you got for part a, and write everything in terms of velocity and its derivatives. Again, once you have that, good luck solving it. :tongue2:
part a) f=mg-mkv^2 = ma =(this is where i may go wrong) m(dv/dx)(dx/dt) =m(dv/dx)v
limited knowledge of differential equations but here goes
x = -∫(v/(kv² + g))dv = -(1/(2k))ln(kv² + g) + C.
final velocity = initial velocity (v=u) when x = 0, C = (1/(2k))ln(ku² + g).
Therefore -2kx = ln(kv² + g) - ln(ku² + g),
and so e^(-2kx) = (kv² + g)/(ku² + g) = (v² + g/k)/(u² + g/k).
manipulating gives v² = (g/k + u²)e^(-2kx) - g/k.
and finally is it too late to take chemistry instead of physics?
To be honest, I'm having trouble understanding your steps. That doesn't mean they're wrong, it just means I can't follow them.
Here's what I had:
[tex] a = g - kv^2 [/tex]
[tex] \frac{dv}{dt} = g - kv^2 [/tex]
Then you did a smart change of variables using the chain rule, which I approve of:
[tex] \frac{dv}{dx}\frac{dx}{dt} = v\frac{dv}{dx} = g - kv^2 [/tex]
Now we can divide both sides through by v:
[tex] \frac{dv}{dx} = \frac{g}{v} - kv [/tex]
I still don't know how to solve this differential equation.:rofl:
Calculus i didnt find too bad, just don't like it :)
mechanics is a problem didnt do any at A level
Thanks for all your help tonight
I have figured out how to solve it, but it is complicated:
Start with
[tex] v\frac{dv}{dx} = g - kv^2 [/tex]
Now, notice that the left hand side looks like something that has already been differentiated using the chain rule. In math, they call such an expression an exact differential, since it is the derivative of something. In particular, "reversing" the chain rule in your head, you can see that:
[tex] v\frac{dv}{dx} = \frac{d}{dx}\left[\frac{1}{2}v^2\right] [/tex].
To verify that this is true, just differentiate the expression in square brackets using the chain rule, and you'll get back what is on the left hand side. So we end up with:
[tex]\frac{d}{dx}\left[\frac{1}{2}v^2\right] = g - kv^2 [/tex].
Let's now introduce a change of variables i.e. a substitution. Let u = (1/2)v2. Then the differential equation becomes:
[tex] \frac{du}{dx} = g - 2ku [/tex]
[tex] \frac{du}{dx} + 2ku = g [/tex]
Now this is a linear differential equation that I DO know how to solve. It can be solved by a method known as the method of integrating factors. If/when you take a course in ordinary differential equations, you will learn this method. Basically, it involves multiplying both sides of the equation by an integrating factor. The integrating factor is a factor that turns the left-hand side into an exact differential. In this case, the left hand side will look like something that has been differentiated using the product rule. You can then "reverse" this differentiation by integrating both sides w.r.t. x. After applying the initial condition u(0) = 0, you'll be able to solve for u(x) and hence for v(x).
The integrating factor is always exp(∫ψdx) where ψ is the coefficient on the second term (the term that has only u in it and no derivatives). So, in this case, ψ = 2k, and the integrating factor becomes exp(2kx). If you multiply both sides by this factor, you should be able to solve the equation.
Edit: I just realized that the initial condition is actually u(h) = 0, not u(0) = 0. So that will change the form of the solution somewhat.
ahh i give up for one night :) 3 hours on one question is longer than i spent completing all the previous 6 questions on the assignment.
will look over it again at some point during the weekend. Dont make plans to keep busy :)
thanks once again
1. What is free fall?
Free fall is a term used to describe the motion of an object that is only influenced by the force of gravity. In other words, it is when an object is falling without any other forces (such as air resistance) acting upon it.
2. What is the equation for velocity in free fall?
The equation for velocity in free fall is v = gt, where v is velocity in meters per second (m/s), g is the acceleration due to gravity (9.8 m/s^2), and t is time in seconds. This equation assumes that there is no air resistance affecting the object.
3. How does air resistance affect free fall?
Air resistance, also known as drag, is a force that opposes the motion of an object through the air. It affects free fall by slowing down the object's velocity as it falls. This is because the force of air resistance increases as the object's velocity increases, eventually reaching a point where it is equal to the force of gravity pulling the object down. This results in a constant velocity known as terminal velocity.
4. What is the equation for calculating air resistance?
The equation for air resistance is Fd = 0.5 * ρ * v^2 * A * Cd, where Fd is the force of air resistance, ρ is the density of the air, v is the velocity of the object, A is the cross-sectional area of the object, and Cd is the drag coefficient which depends on the shape of the object. This equation can be used to calculate the amount of air resistance on an object at a given velocity.
5. How does air resistance affect the time it takes for an object to reach the ground?
Air resistance does not affect the time it takes for an object to reach the ground. This is because the force of air resistance is proportional to the velocity of the object, but the acceleration due to gravity is constant. Therefore, the force of gravity will always be greater than the force of air resistance, causing the object to continue accelerating towards the ground at a constant rate of 9.8 m/s^2 regardless of air resistance.
  • Classical Physics
