Homework Help: Free Fall Tennis Ball Question
  1. Aug 14, 2013 #1
    A tennis ball is thrown upward with and reaches height of 18 m. What maximum height can reach this ball on the where acceleration of free fall is 6 times less than g? In both cases initial velocity is same. [sic] (excuse my physics teacher's grammar, don't shoot the messenger! :tongue:)
    g= 9.81 m/s2
    x= distance or displacement
    v= velocity
    a=acceleration (which is g)
    Max Height is at V=0
    2. Relevant equations
    [itex]V=\sqrt{2gx}[/itex]
    [itex]ΔX=V_it + (1/2) at^2[/itex]
    3. The attempt at a solution
    [itex]9.81/6=1.64[/itex]
    [itex]V^2=2(1.64)x[/itex]
    Initial velocity in a free fall is 0 m/s, right? If so, v=0 and then x=0
    In such a case, it would be odd for the max height to be 0 m.
  3. Aug 14, 2013 #2
    If the ball is thrown upward, then its initial velocity cannot be zero.
    Note the formulation does not require that the initial velocity be zero; it just says it is the same in both cases.
  4. Aug 14, 2013 #3
    So, I can just use any velocity?
    Or must I use a velocity that intersects?
    Considering time is neither given nor required, can I use
    [itex]V_f = V_i+at[/itex]?
    [itex]V_f=0[/itex] to find the maximum.
    I use the gravities as the slope. However, the lines intersect at the origin, where time and velocity equal 0.
    [itex]0 = -1.64 t[/itex]
    [itex]0 = -9.81 t[/itex]
  5. Aug 14, 2013 #4
    gneill
    Staff: Mentor
    You can find the initial velocity using your first Relevant Equation for the stated conditions that the ball reaches a height of 18 m when gravity is g.
    Note that you are taking advantage of the fact that ideal free-fall trajectories are symmetric with respect to time reversal, so if a ball launched upwards with some velocity V reaches maximum height H, then a ball dropped from height H will reach a final velocity V just before impact with the ground.
  6. Aug 15, 2013 #5
    Does that really matter what the initial velocity is numerically? You know it is the same. That means the initial kinetic energy is the same.
Have something to add?
Draft saved Draft deleted
