Exploring the Horizontal Displacement of a Rock Kicked Off a 321m High Bridge
In summary, the rock will travel 321m vertically in free fall regardless of whether it is dropped or kicked off the bridge. The horizontal velocity of the rock will not affect its vertical displacement, as it will still fall straight down with a velocity of 9.81 t_\mathrm{fall}. The path of the rock may appear to be a curve, but it will still reach the same vertical distance of 321m.
MIA6
233
A bridge rises 321m above the Arkansas river. Suppose you kick a rock horizontally off the bridge. The magnitude of the rock's horizontal displacement is 45.0 m. Fine the speed at which the rock was kicked. (This is not what i ask you here)
Does the ball travel 321m vertically in free fall? If so, then i have a question, we know that 321m is a vertical path straight down to the river, which is perpendicular. but when we draw the path of the ball that travels is half of a parabola, which is a curve, so if we have the common sense we know that if we measure the distances of these two paths, they are different. THe curve is longer than the straight line. so i don't know if it travels 321m vertically in free fall.
Hope you can explain it to me, thank you.
I don't really understand your question, but I'll try to explain a little.
It does travel 321 m in free fall. It cannot travel less (or it would hang above the river) or more (it would free-fall inside the river). It doesn't matter if you kick it off horiontally or drop it over the edge. Assuming no friction, the horizontal velocity of the rock will not change. That is, if you drop it, it will fall straight down and plunge into the water with a velocity of [itex]9.81 t_\mathrm{fall}[/itex] aimed straight down; if you kick it off at 20 m/s it will come down with a velocity that is aimed slightly downwards, slightly forwards (in fact, it will have a horizontal component of 20 m/s, and a vertical component of [itex]9.81 t_\mathrm{fall}[/itex]). You should add them vectorially (if you know how to do that), or you can draw it in a picture by drawing the horizontal and vertical lines (on scale) - then the final velocity will be the tip of the parallelogram spanned by those.
ok, i mean that the pictures is like this:
1)if there is no horizontal velocity, it would go straight down perpendicularly:
/ (I know the straight line is 321m)
2) However, there is horizonal velocity involved in this question, so it travels down like half of a parabola, a curve
/ (sorry, i can't show it having a slope, so just imagine it. then, this is a curve, does the ball still travel 321m straight down?) if you still don't understand what i mean, here: a straight line between two points is the shortest if we measure, a curve between the same two points would be longer than the straight line if you use ruler to measure it mathematically.
1. What is the purpose of exploring the horizontal displacement of a rock kicked off a 321m high bridge?
The purpose of this exploration is to understand the laws of motion and the effects of gravity on a falling object. By measuring the horizontal displacement of a rock kicked off a high bridge, we can gather data and make calculations to better understand these concepts.
2. How is the horizontal displacement of the rock measured?
The horizontal displacement is measured by using a measuring device, such as a ruler or a measuring tape, to determine the distance between the edge of the bridge and the point where the rock lands. This distance is known as the range.
3. What factors can affect the horizontal displacement of the rock?
The main factor that affects the horizontal displacement is air resistance. Other factors that may also have a slight impact include the shape and weight of the rock, as well as external forces such as wind.
4. How does the height of the bridge impact the horizontal displacement of the rock?
The higher the bridge, the longer the rock will have to fall and the higher its velocity will be. This can result in a longer horizontal displacement as the rock will have more time to travel before hitting the ground.
5. What are some real-world applications of studying the horizontal displacement of a falling object?
Studying the horizontal displacement of a falling object has many real-world applications, such as predicting the trajectory of a projectile, understanding the effects of air resistance on objects in motion, and designing safer structures such as bridges and buildings.
9K
