Free falling body question
  • Thread starter trojansc82
Under some circumstances a falling body B of mass m encounters air resistance proportional to its instantanous velocity v. Use Newton's second law to find the differential equation for the velocity of v of the body at time t. Recall that acceleration a = dv/dt. Assume in this case that the positive direction is downward.
F = ma
a = dv/dt
air resistance = kv
kv = mg
kv = mg (dv/dt)
(dv/dt) (k/m) v = g
The solution in the text is (dv/dt) + (k/m) v = g.
I'm failing to understand why (dv/dt) is added to (k/m).
Answers and Replies
Doc Al
Mentor
44,994
1,268
What forces act on the object? What's the net force?
Net force = mg + km?
Doc Al
Mentor
44,994
1,268
mg, yes. But what is 'km'? There's a force proportional to the velocity, so show that. (What direction--and thus sign--does it have?)
So then v = mg?
I'm really confused....I don't feel like this question provides enough information to set up an equation.
I'm only able to set up this equation:
F = ma, letting F = kv, m = mg, and a = (dv/dt).
kv = mg (dv/dt)
Simplified:
(dv/dt) (k/m) v = g
Doc Al
Mentor
44,994
1,268
So then v = mg?
:confused: The units don't even match. (You can't set a velocity equal to a force.)
There are two forces acting: One is the weight (mg); the other is the air resistance, which you correctly have as kv (but what sign should it have?).
(Setting m = mg doesn't make much sense!)
So write the two forces, add them up to get the net force (pay attention to the signs of the forces), then apply ΣF = ma = m(dv/dt). That will give you the equation you need.
Net force = mg -kv ?
Doc Al
Mentor
44,994
1,268
Related Threads on Free falling body question
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
9K
