Free Vector Space Explained: Geroch & Matheinste
In summary: They are the same in the sense that there is a bijection between them, the bijection being the adjunction between the functors Free and For.In summary, a free vector space can be defined starting from any set and is characterized by having a basis equal to that set. It is useful in mathematics because it simplifies the process of defining linear maps and adding structure to a vector space by transforming it into a problem of defining arbitrary functions on the basis. This is a result of the adjointness of the free and forgetful functors, which equates linear maps from a free vector space to another vector space with arbitrary functions from the basis to the underlying set of the other vector space.
matheinste
1,068
Hello everyone.
I came across the term free vector space in a book on mathematical physics by Geroch but cannot find them in any other of my books. Can someone give me an explanation of how a free vector space differs from a standard vector space. Geroch says that any set can be made into a free vector space but is this not true for a standard vector space by considering the set members as vectors and defining appropriate vector addition and scalar multiplication laws and a zero vector ?
Thanks Matheinste
You can define a free vector space starting from the underlying set of any vector space, but it will of course have no relation to the one you started with.
If you start with a set of cardinality c, then the free vector space over it will have _dimension_ c.
the adjective free, in matts disc ussion, and in your question, is part of a phrase, "free on a given set".
i.e. there is no such thing as a free vector space, or rather all vector spaces are free so the term is uncommon, but the phrase this vector space is "free on the set S", just means the set S is the basis.
so every vector space is free on some set, namely on any basis. and what matt is saying is that conversely, given any set S, there is a vector space of dimension equal to the cardinality of S, which is free on S.contrariwise, given any set S and any commutative ring R with 1, there is amodule which is free on S, but now it is no longer true that all R modules are free on some set, since some R modules have non trivial annihilator ideals. such as R/I where I is a nontrivial ideal.
Thankyou both for your answers which more or less confirmed what I thought was the case. This has cleared the problem up nicely.
Thanks again Matheinste.
put another way, the forgetful functor F from k-vector spaces to sets has an adjoint functor Fr, the free functor from sets to k-vector spaces. this free functor has the property that every k-vector space is isomorphic to something in the image of Fr.
this is an in your face way of saying that every vector space has a basis, every set is a basis of some vector space, and that linear transformations are determined by what they do to a basis, and you can have that be anything you like.
hello all.
It would help my understanding if i knew the motivation for the construction of free vector spaces over a set and also the uses which i have been asssured they have.
Any help would be gratefully received.
Matheinste.
Every vector spaces is a free vector space, so they're automatically interesting. Plus this formal sum idea gives you group algebras, for example. It is a way of adding more structure to something - turning a group into an algebra.
Thankyou for your reply Matt
I have read some more sources and what i originally thought seems to be correct ie all sets can be made into vector spaces with the required definitions of vector additon etc. What threw me was the seemingly complicated manner in which the sources i read derived these free vector spaces. i understand that some things that are intuitively obvious are not always correct hence the need for ( sometimes complicated ) rigorous definition. Its the necessary rigour that i can't always follow.i hope this will come with experience.
Matheinste.
Hello all.
I have attached an extract from A Course in Modern Mathematical Physics by Szekeres. My question is why can we not just use the given set as a basis as it stands without the other "operations".
View attachment FreeVectorSpace.pdf
Matheinste.
I don't really understand the question...
I will note that, for their definitions, the elements of S are not even vectors in F(S).
Thanks Hurky.
I see what you mean. for the "intuitive" first part of the definition an arbitrary set is used and for the "rigorous" second part a set of functions is used.
I think i need to stop and think exactly what i want to know before i can expect others to be able to help me.
I will go backwards a few paces and ask a very basic question. What i have learned from this thread is that all vector spaces are free vector spaces (on some set?). If i am given a vector space can i call it, as it stands, without doing anything to it, a free vector space on a set.
Matheinste.
but perhaps we have not yet made fully clear the importance of that statement. in my response above i mentioned that a linear map on a free space on the set S is determined by what it does to that set. that is the importance of freeness.
i.e. the main job in mathematics is to define maps, and that job is as easy as possible only for functions with no structure to preserve. free spaces transform the job of defining structure preserving maps on the space Fr(S) into arbitrary functiions on the basis S. thus they solve the problem of defining linear maps in as simple a way as possible.
the general concept of adjoint functors describes this process of equating maps of one kind with maps of another kind.
i.e. the adjointness of the free and forgetful functors Free and For says that
linear maps from Free(S) to W, where Free(S) is the vector space free on the basis S, are the same as arbitrary functions from S to the underlying set For(W) of the vector space W.
1. What is a free vector space?
A free vector space is a mathematical concept that represents a collection of vectors that can be added and multiplied by scalars without any restrictions. This means that any combination of vectors and scalars within the space is also considered a vector within the space. It is a fundamental concept in linear algebra and is used in various fields of science and engineering.
2. How is a free vector space different from other vector spaces?
A free vector space is different from other vector spaces in that it has a basis, which is a set of linearly independent vectors that span the entire space. This means that any vector in the space can be expressed as a unique combination of the basis vectors. Other vector spaces may have restrictions on how vectors can be added or multiplied, or may not have a basis at all.
3. What is the significance of Geroch & Matheinste's explanation of free vector spaces?
Geroch & Matheinste's explanation of free vector spaces is significant because it provides a clear and rigorous definition of the concept, which can often be abstract and difficult to understand. Their explanation also introduces the concept of dual spaces, which is important in understanding the relationship between vectors and linear functionals.
4. How are free vector spaces used in science?
Free vector spaces are used in various areas of science, including physics, engineering, and computer science. They are especially important in physics, where they are used to describe physical quantities such as forces, velocities, and electric fields. In computer science, free vector spaces are used in fields such as computer graphics and machine learning.
5. Can you give an example of a free vector space?
One example of a free vector space is the set of all polynomials with real coefficients. The basis of this space is the set of monomials, such as 1, x, x², x³, and so on. Any polynomial in this space can be expressed as a unique combination of these basis elements, and addition and scalar multiplication can be performed on them without any restrictions.
  • Linear and Abstract Algebra
9K
