Freely falling objects
  1. Jan 21, 2012 #1
    two balls are thrown from a cliff. one is thrown directly up, the other directly down, each with the same initial speed, and both hit the ground below the cliff. which ball hits the ground at the greater speed?
    3. The attempt at a solution
    I know the answer is that they both his the ground at the same speed. But why?
  3. Jan 21, 2012 #2
    Curious3141
    This is only true when drag from the air is neglected, btw.
    Consider conservation of energy. For each ball, PE + KE is a constant. Think about what happens to the ball thrown upward. What is its speed at the instant when it comes back downward to pass the point it was thrown from?
  4. Jan 21, 2012 #3
    When it returns to the position it started out as, then the velocity should equal the initial velocity.
  5. Jan 21, 2012 #4
    Curious3141
    Careful there. When it was thrown upward, its direction was upward. When it comes back down, its direction is reversed. Since velocity is a vector with both magnitude and direction, you can't say the final velocity equals the initial velocity. You can, however, say that the final speed equals the initial speed.
    So the ball comes back down with the same speed it was thrown up at. Now its velocity (both magnitude and direction) is the same as the second ball that was thrown downward from the start. Can you immediately see the rest of the way to the solution?
  6. Jan 21, 2012 #5
    Got it! Thank you!
  7. Jan 21, 2012 #6
    Curious3141
    You're welcome. :smile:
