Homework Help: Freezing point of mercury
  1. Oct 10, 2009 #1
    The enthalpy of fusion of mercury is 2.292 kJ/mol, and its normal freezing point is 234.3 K with a change in molar volume of +0.517 cm/mol on melting. At what temperature will the bottom of a column of mercury (density 13.6 g /cm3) of height 10.0 m be expected to freeze?
    2. Relevant equations
    p = [tex]\rho[/tex]gh
    p = p* + [([tex]\Delta[/tex]fusH)[tex]/[/tex](T*[tex]\Delta[/tex]fusV)]/(T - T*)
    3. The attempt at a solution
    I calculated the pressure in the column of mercury using the first equation provided above. I then solved the second equation for T, plugged in the given values, with p*= 101 kPa and T* = 234.3 K (the normal pressure and boiling point).
    I get an answer of 234.2 K, which doesn't make sense, since when you raise the pressure, shouldn't you get a higher temperature freezing/melting point? I would expect it changes more than 0.1 K anyways.
    Am I using the correct equation?
    Thanks!
  3. Nov 26, 2016 #2
    Bystander
    What's the slope of the m.p. line? Positive? Or, negative?
    Water changes 0.01 K/atm, and has which slope?
    Yes.
Have something to add?
Draft saved Draft deleted
Loading...
Similar Threads for Freezing point mercury
Why is the boiling point of 2-propanol lower than 1-propanol
