Frequency of an organ pipe
  • Thread starter zorro
Given two statements:
Statement 1: Narrower the open organ
pipe, higher will be the
pitch.
Statement 2: The frequency of open
organ pipe depends on its
radius.
(1) Both statements statement 1 and
statement 2 are true and statement 2
is reason for statement 1
(2) Both statement 1 and statement 2
are true but statement 2 is not
(3) Statement 1 is true but statement 2
is false
(4) Statement 1 is false but statement 2
is true
I believe the answer is (3) because the expression for frequency of the sound through an organ pipe depends on velocity and wavelength which do not depend on radius of the pipe. But this is wrong.
Answers and Replies
tiny-tim
25,836
251
pitch.
radius.
"narrower" means thinner, so smaller radius :wink:
Hi tiny-tim! :smile:
I'm afraid you did not get my question right.
100
Abdul,look up "end correction"
tiny-tim
25,836
251
But your own reasoning shows that statement (1) cannot be true. :wink:
(and i'm pretty sure you're intended to ignore the open end correction)
Yeah I know about it but can 'end correction' be the sole reason for its dependency on radius?
I did not notice that :biggrin:
If we ignore the end correction then based on what mathematical relationship can we deduce the correct answer given [(1)]?
100
The question didn't state that the frequency is solely dependant on radius but the implication is there.A badly written question.
tiny-tim
25,836
251
pitch.
radius.
I thought you said Statement 2 was false? :confused:
Yes you are right, I thought that statement 2 is false (so option 3 according to me). But the correct answer given is option (1), and I asked you with what mathematical relationship can we deduce it?
100
You dont need mathematical relationships,just look at it and if necessary sketch it.If the pipe is narrower then the effective length of the pipe(actual length plus added length due to end corrections)is shorter.This results in shorter wavelengths and higher frequencies.
Related Threads on Frequency of an organ pipe
  • Last Post
  • Last Post
10K
  • Last Post
9K
17K
26K
  • Last Post
  • Last Post
  • Last Post
