Frequency of oscillation
  • Thread starter goonking
Consider a human leg to be a rod of uniform density pivoting about one end. What will the frequency of oscillation be for a leg with a length of 0.82 meters?
I believe we need the imagine the leg as a rod, so the moment of inertia would be = 1/3 m L2
so is the the pivot point at the hips and the whole leg is moving?
or just the shin is moving and the knee is the pivot point? if this it the case, then do be divide .82m by 2?
Answers and Replies
rude man
Insights Author
827
Yes
No. It says 'pivoting about one end' so it's not pivoting about the knee.
haruspex
Insights Author
2020 Award
36,726
7,078
It doesn't matter whether it represents the shin or the whole leg, just do as it says: treat it as a rod of length .82m pivoted at one end.
so I would just use T = 2 pi sqrt(L/g)?
which comes out to be 1.81 seconds
frequency = 1/T = 1/1.81 = .55 Hz
is that correct?
haruspex
Insights Author
2020 Award
36,726
7,078
No, I said a rod of that length, not a simple pendulum of that length. Use the moment of inertia you mentioned in the OP.
ok, I got the the new answer to be .675 Hz after using the physical pendulum formula . Thanks.
Related Threads on Frequency of oscillation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
9K
