How Do You Calculate the Frequency and Maximum Velocity of a Mass on a Spring?
In summary, the conversation discusses the calculation of the expected frequency of vibration and the maximum velocity of a mass attached to a spring. The initial displacement of the mass and the time measurements are given, and it is noted that there is no information about the spring constant or mass. However, it is mentioned that to find the period of a spring, one does not need to know these values and can calculate it using the equation T = 2\pi\sqrt{\frac{k}{m}}. The calculation for the spring constant can be substituted into this equation, and the final equation will only contain variables that can be calculated.
Kev1n
40
1. A mass attached to the lower end of a vertical spring causes the spring to extend 25mm to its equilibrium position. The mass is then displaced a further 20mm and released. A trace of the vibration and time measurements are taken. From these measurements it can be seen that the displacement from equilibrium position is 19.2 when the time is 0.05s
A. Calculate the expected frequeny of vibration, B. Calculate the maximm velocity of the mass. I have struggled here as ther is no (k) for the spring or mass
It would be appreciated if anyone could havea look over at my attempt and comment, thanks
2. w=sqrt(k/m), mg=kl, m=kl/g
3. A. w=sqrt (k/m), l = 25mm so 0.25m, g =9.81
m = l/g = 0.025
Basically now can see where to go without k
To find the period of a spring you do not need to know the mass or the spring constant.
Substitute the calculation for the spring constant into the equation for the period, you should find that you are left with only variables you are able to calculate.
T = 2[tex]\pi[/tex][tex]\sqrt{\frac{k}{m}}[/tex]
k = [tex]\frac{F}{x}[/tex]
And think about the calculation for F.
so substitute in the formula for k = w^2m, w = 2*pi*f, so f = sqrt(k/m)/(2*pi)
B. To calculate the maximum velocity of the mass, we can use the formula vmax = A*w, where A is the amplitude of the vibration and w is the angular frequency. In this case, A = 19.2mm = 0.0192m, and we can use the same value for w that we calculated in part A. So, vmax = 0.0192 * sqrt(k/m)/(2*pi) = 0.0096*sqrt(k/m) m/s.
As you mentioned, there is no given value for k or mass in this scenario, so we cannot give a specific numerical answer for the frequency or maximum velocity. However, we can use the given information and formulas to determine the relationship between k and m, and ultimately the frequency and maximum velocity.
1. What is frequency of vibration?
The frequency of vibration is the number of oscillations or cycles that occur in one second. It is measured in units of hertz (Hz).
2. How does frequency of vibration affect sound?
The frequency of vibration is directly related to the pitch of a sound. A higher frequency results in a higher pitch, while a lower frequency results in a lower pitch.
3. What is resonance and how does it relate to frequency of vibration?
Resonance occurs when an object vibrates at its natural frequency in response to an external force. This natural frequency is determined by the physical properties of the object, including its frequency of vibration.
4. Can the frequency of vibration be changed?
Yes, the frequency of vibration can be changed by altering the force or energy applied to the object, or by changing the physical properties of the object itself.
5. How is frequency of vibration used in science and technology?
The study of frequency of vibration is used in many fields, including acoustics, mechanics, and electronics. It is also used in technologies such as sonar, ultrasound, and radio communication.
