How Do You Calculate the Frequency of Vibration for a Mass on a Spring?
In summary, a mass attached to a vertical spring extends the spring by 25mm at its equilibrium position. When the mass is displaced by 20mm and released, it vibrates with a displacement of 19.2mm at 0.05s. Using the formula x(t) = Asin(ωt+δ) and the given values, the frequency of vibration can be found by solving for ω and then dividing by 2π. In this case, the frequency is approximately 5.68 Hz.
DR1
36
1. Homework Statement
a mass attached to the lower end of a vertical spring causes the spring to extend by 25mm to its equilibrium position. The mass is then displaced a further 20mm and released. a trace of the vibration and time mesurements are taken. From these mesurements it can be seen that the displacement from the equilibrium position is 19.2mm when the time is 0.05s
A) calculate the expected frequency of vibration
B) calculate the maximum acceleration of the mass
C) calculate the maximum velocity of the mass
2. Homework Equations
i believe the frequency formule to be f=1/T Hz, or the displacement formule x=Asin(wt+o) both of which I am sure are part of the solution but i can not see how to use them with the info given
3. The Attempt at a Solution
i am having an problem knowing were to start with this as i believe the key is finding out the weight of the Mass any help or pointers would be greatfully recived
many thanks
You need to plug in the formula that you have for x(t) to find ω. If it is frequency f that you are looking for, them f = 2π/ω. Begin by identifying the symbols in the equation
x(t) = A sin(ωt+δ)
What is A, what is δ? Use the fact that at t = 0, the mass is at 20 mm from the equilibrium position and is not moving (instantaneously).
x(t) = A sin(ωt+δ)
ok so A is amplitude which is the maximum displacement = 0.02m
so putting all the info in gets 0.020=0.020sin(w0+angle)
therefore 0.02/0.02=sinw which is 0.017 this does not look right to me i am obviously missing something please help
No. Try again. What do you get if you solve 0.02 = 0.02 sin(ω*0+δ)? Any number multiplied by zero is zero, so there is no ω in the expression.
ok so i am still mot following I am afraid i am using the figures as
displacement (x) = 0.020
time (t)=0
Amplitude (A)=0.020
initial Angle (O)= 0
are these the correct figures to use or am i best using the figures once released ie
x=0.0192
t=0.05
A=0.02
O=0
i am trying to reaarange the formule for w but failing miserably as it is giving me silly answers
im sorry if i am missing the obvious
0.02 sin(ω*0+δ) = 0.02
sin(0+δ) = 0.02/0.02
sin(δ) = 1
δ = ?
sin(δ) = 1
δ = ?
δ=90
if i were to then put this with the figures gained once released
0.0192=0.02sin(w*0.05+90) how do i get w on its own? do i need to mutiply out the barckets
ω*0.05+90=arcsin(0.0192/0.02)
ok so reaaranging for w i am getting
(arcsin(0.0192/0.02)/0.05)-90=1384.796 this sounds to big to me were am i going wrong
alternatively if i do ( Arcsin(0.0192/0.02))/90.05 = 0.82rads-1 this sounds better? could you confirm either way
You put in the numbers incorrectly. Also, depending on the settings of your calculator, the arcsine may return the angle in degrees or radians. It's up to you to figure this out - I don't have your calculator in front of me.
Smaller but not necessarily better. How did that 90.05 get in the denominator? It seems you need to improve your algebra skills.
I am really struggling with this, my maths skills have never been particularly great as I am sure I am demonstrating!
You stated the above, to get w on its own I cannot work out whether I group up 0.05+90 and then put it in the denominator, or if I move both individually, and therefore put 0.05 in the denominator and minus 90 from the overall result?
I no longer have the book for my calculator so will try and find a manual online re the rads/degrees issue
Thanks for your assistance, it is appreciated, I know you must be getting frustrated with me!
If you are calculating the arcsine in radians, convert the 90 to π/2. Then move 90 (or π/2) over to other side and change its sign. Now divide everything on the right side and on the left side by 0.05. What do you get?
Am i right in say that my calculator is working out the arcsine in degrees as the result I get is 73.74?
Yes you are right in that regard. Now proceed with the calculation of ω as I indicated.
(73.74-90)/0.05 = -325.2
alternatively if I do the rads option (having now found a guide for my calculator!) i get
(1.287002218-(π/2))/0.05 = 16.38
am i right in concluding that the first answer is in degrees and the second one is in rads so its the second one that I want?
Correct, it is rads that you want, but your numbers are wrong. What do you get when you subtract π/2 from 1.287?
-0.2838?
then dividing by 0.05 gives -5.676 as my answer?
and then dividing that by 2π gives me the answer in hertz?
Right. However, if you solve for the frequency, you get a negative number and that's not cool. Note that after one period T has gone by, the angle returns to the exact same value of -0.2838. This means that, for any time t, we can write
ω(t - T) = -0.2838.
Take out the parentheses and you get
ωt - ωT = -0.2838.
Now ωT = 2π. Put that in the equation, move it over to the other side and change its sign. Then solve for ω. You should get a positive value.
I know this sounds complicated. There is a simpler way to write x(t), but you should stick with this description until is it is finished. I don't want you to be unnecessarily confused.
Good luck. I have to sign off for now.
**** Edit ****
This posting refers to DR1's posting #18.
Ok thank you for that, in that case my answer is that w = 119.99 rads.
And in hertz I make the frequency 19.097?
Thanks again for your assistance
That looks right.
1. What is frequency of vibration?
Frequency of vibration is the number of complete oscillations or cycles that occur in a vibrating object per unit time. It is measured in hertz (Hz) and can also be described as the rate at which an object vibrates back and forth.
2. How is frequency of vibration related to energy?
The higher the frequency of vibration, the higher the energy of the vibrating object. This is because objects with higher frequencies require more energy to maintain their rapid oscillations.
3. What factors affect the frequency of vibration?
The frequency of vibration can be affected by the stiffness, mass, and length of the vibrating object. The medium in which the object is vibrating can also play a role in determining its frequency.
4. How is frequency of vibration measured?
Frequency of vibration can be measured using instruments such as a frequency counter or a spectrum analyzer. It can also be calculated by counting the number of oscillations per unit time.
5. What are some real-life examples of frequency of vibration?
Frequency of vibration can be observed in many everyday objects, such as musical instruments, pendulums, and tuning forks. It also plays a role in the functioning of electronic devices, such as radios and cell phones.
