Frequency of wire oscillations
In summary: The minus sign comes from the fact that the tension in the string is pulling in opposite directions on the two sides of the wire - the net force points downwards.
cdummie
147
There's a horizontal thin wire whose mass is negligible and whose length is l=1m. It is strained with constant force F=10N. If we place a tiny pellet in the middle of wire (mass of pellet is m=1g) and then we bring wire out of equilibrium position (moving out of it's original position is normal to the wire, 90 degrees). Determine the frequency of oscillation of wire.
ω=2πf
We know that, since this is oscillation motion, following equation holds:
x'' + ω^2 x=0 ,where x is amplitude, so we could actually try to find acceleration (a=x'') in function of amplitude x, and then, expression multiplied by x would be ω^2 and then, since ω=2πf we could easily find f here, but i don't know how to determine x''. Any ideas?
Draw a diagram with all relevant forces.
Note: That answer works for all mechanics problems where no such diagram has been drawn yet.
Likes cdummie
The restoring force is twice the vertical component of the tension in the wire - hope it helps :smile: - make a diagram and consider the whole length of the wire
Likes cdummie
This is all i have, i don't know how to draw force F, force F1 is the force that pulls the pellet out of equilibrium position. How can i draw the force that strains wire?
I don't understand you very well, why is restoring force (if by restoring force you mean the force that tries to return wire to original position) is twice the component of the tension in the wire?
There are two tension forces (equal in magnitude but they are not always on the same direction as you can possibly understand) acting on the pellet, one from the half left and one from the half right portion of the wire. You must find the net force (this net force will be the restoring force actually) acting on the pellet and express it in the form k*x where x is the vertical distance from the middle (x is actually the height of the triangle you draw). You might find useful the equality ##cos\theta=\frac{x}{\frac{L}{2}}##
Likes cdummie
It doesn't oscillate as long as you pull it, so you want to consider the case where it is not pulled any more.
There is a constant tension of 10 N along the wire. Both sides of the wire pull the mass in the direction of the wire, with a force of 10 N. The two forces are not exactly opposite to each other, which leads to a net force.
Likes cdummie
The mass oscillates vertically. The force responsible for these oscillations is directed along along its path,
that is according to Newton's second law the force and acceleration is in the same direction.
This force is supplied by the tension in the string, but only the vertical components of the tension, that
is the components of the tension on both sides contributes.
Likes cdummie
mfb said:
It doesn't oscillate as long as you pull it, so you want to consider the case where it is not pulled any more.There is a constant tension of 10 N along the wire. Both sides of the wire pull the mass in the direction of the wire, with a force of 10 N. The two forces are not exactly opposite to each other, which leads to a net force.
Ok, let's see if i understand this now.
This is the same image i posted before, it just has that one angle labeled.
If force that is straining this wire is F and it is acting both from the left and right part of wire, then the net force that is acting is sum of those two forces along the height of the triangle this forces form, right? If that is so, then, since sinθ=F1/F it means that F1=Fsinθ, but there are two F forces so F1=2Fsinθ , but i am still not quite sure about this, since F1 acts in the direction opposite to the direction of the force Fsinθ does it means that force i am looking for is actually F1=-2Fsinθ , is that right?
Likes Delta2
What you saying is basically correct but to see if you get it right you must draw the tension forces at the upper vertex of the triangle, the forces are such that the net force is pointing downwards actually. The minus sign comes from the fact that the direction of the net force is always such that it is opposite to the direction of y, where ##sin\theta=\frac{y}{\frac{L}{2}+\epsilon}##. if y is positive (as you draw it) the net force will be pointing downwards, so will be negative, if y is negative the net force will be pointing upwards). Why that happens is because that is just how the wire behaves, if you push it upwards the restoring force will be such as to bring it downwards, if you push it downwards the restoring force will be such as to bring it upwards.
Likes cdummie
Right.
A negative value for F1 is fine, you'll need that sign later when you consider the (now defined as positive) position of the object.
Likes cdummie
The two vertical components of the tension in the wire are directed downwards, F1, while the pellet is displaced upwards from the equilibrium position.
Likes cdummie and Delta2
1. What is the definition of frequency of wire oscillations?
The frequency of wire oscillations is the number of times a wire vibrates or moves back and forth in a given period of time. It is measured in Hertz (Hz) or cycles per second.
2. How is the frequency of wire oscillations related to its tension and length?
The frequency of wire oscillations is directly proportional to the tension in the wire and inversely proportional to its length. This means that as tension increases, the frequency also increases, and as length increases, the frequency decreases.
3. What factors affect the frequency of wire oscillations?
The factors that affect the frequency of wire oscillations include the tension, length, mass of the wire, and the medium through which it is vibrating. Other factors such as temperature, humidity, and material of the wire can also have an impact.
4. How is the frequency of wire oscillations measured?
The frequency of wire oscillations can be measured using a device called an oscilloscope. This instrument measures the time it takes for the wire to complete one full oscillation and calculates the frequency based on this time.
5. What is the significance of understanding the frequency of wire oscillations?
Understanding the frequency of wire oscillations is important in various fields such as physics, engineering, and music. It helps in designing and building structures that can withstand vibrations, creating musical instruments with specific tones, and studying the behavior of waves and vibrations in different mediums.
