jescriba
- 8
I'm trying to build a switch that is closed only when the input signal is roughly the same signal over some time. So when ever the frequency of the input changes by a significant amount the switch opens, and when the input frequency is roughly constant the switch is closed. I'm building this in analog and wanted some advice/ideas. 1) I was thinking of taking the signal and passing it through a RC Highpass then putting the signal through a differential op amp configuration to subtract the incoming signal with a slightly delayed signal. And if the difference is sufficiently small (in reality it won't be zero) to go through a transistor not gate. 2) The other way I was thinking of doing this is passing it through some sort of comparator test.
Would this in practice actually work?
Any suggestions and recommendations welcome. Thanks.
