Friction and Constant velocity
  • Thread starter CaptainSFS
CaptainSFS
58
A car of mas m = 1000kg is sliding down a hill. The coefficients of friction between the car's tires and the ground are us=0.89 and uk=0.61. For what inclination angle will the car slide down the hill with a constant velocity?
Now I realize that because it is constant velocity, the acceleration is 0, so the summation of the forces needs to be 0, but i don't know how to set this up. Any help?
Thanks. :)
Answers and Replies
tiny-tim
25,838
255
Hi CaptainSFS! :smile:
Hint: there are only three forces … the weight, the normal force, and the friction force … so set up a force triangle :smile:
CaptainSFS
58
hello, yes, so i have my two frictional forces pointing upwards on the slope. I set it up like this... (1000)(9.81cos(theta))(.89)+(1000)(9.81cos(theta))(.61)-?=0 ...If this is correct, which I am not so sure b/c it just seems like I wouldn't be able to create an opposite force to equal it, so that the acceleration is 0. These frictional forces really confuse me, and I feel like I keep setting it up wrong.
tiny-tim
25,838
255
Nooo …
i] you can't have both kinetic friction and static friction … it's one or the other
ii] what about the weight force?
CaptainSFS
58
okay, so I'm assuming them I will be using the static coefficient because that's the kind tires use on pavement and whatnot. For the weight force... would that be the force pulling the car down the slope? m*g*sin(theta)?
or do u mean the weight force as 1000*9.81?
tiny-tim
25,838
255
Whoa!
that would be for wheels that are rolling
the car is sliding (in other words, the wheels are locked)
the weight force is mg, and you use its component in the required direction.
CaptainSFS
58
okay, so if I'm using it in the required direction, don't I have to use m*g*sin(theta) because gravity isn't pulling it from the side, it's pulling straight down on it?
tiny-tim
25,838
255
Yes! Get on with it! :rolleyes:
CaptainSFS
58
thanks!
Suggested for: Friction and Constant velocity
