Calculating Tension in Friction & Pulley: Solving for a=3 m/s^2
In summary: No, there are three horizontal forces on the block. There is the force of gravity (mg), the force of the string connected to the block (T), and the force of the truck (a).You know which way the block will move relative to the car (since the string neither stretches nor breaks).I meant the force of the truck in forward motion.
  • #71
haruspex said:
Right. So how much closer is the block to the pulley?
haruspex said:
It is one metre closer to the pulley. But the pulley has moved how far?
haruspex said:
Right. So the pulley is one metre further from the wall, and the block is one metre closer to the pulley. So how far has the block moved away from the wall?
By all these questions do you want to say that distance covered by car=distance covered by block
  • #72
No: if the block would NOT be connected to the wall by this wire (and it would NOT move wrt the flat car), THEN the distance covered by the block would be equal to the distance covered by the flat car. So
try again. You have one more attempt left :smile:
Likes gracy
  • #73
Is my post #70 correct?
  • #74
As incorrect as #71, since to me these two appear equivalent. The block moves on the car, so distance covered by car ##\ne## distance covered by block
  • #75
Distance covered by block would be equal to shorter length of string(the region of string which connects block and pulley).That is block will reach where pulley was.
  • #76
That is still saying the block moved by 1 meter ([edit] well, not really, but never mind (*) ). Is it also what you mean to say ?
Would it help you if you made a drawing of the intial situation and one of the situation where the flat car has moved over some distance ?
Or perhaps you do a little experiment where you attach a wire to a fixed point (the wall) on one end and to some object (the block) on the other. Let you finger play the role of the pulley and move your finger by 10 cm. How far did the object move ?
(*) you can easily see that can't be right: imagine the car is fifty meters long and moves by 1 m. No way the block is "where the pulley was".
  • #77
That's why I answered that Distance covered by block would be equal to shorter length of string(the region of string which connects block and pulley).That is block will reach where pulley was.
  • #78
How to interpret it.
  • #79
If the pulley moves 1 m away from the wall, it has to reel in the block by 1 m. So the pulley moves 1 m and pulls in the block by 1m. Over what distance has the block moved wrt the wall ?
The length itself of the shorter section has nothing to do with it. It's about how much that length has changed that's relevant.
  • #80
BvU said:
It's about how much that length has changed .
1 meter?
  • #81
Does that mean distance between wall and pulley is 1 meter?
  • #82
Yes, that length has changed 1 meter: the pulley reeled it in by 1 meter. he pulley itself moved by 1 meter. How much has the block moved wrt the wall ?
Likes gracy
  • #83
No, distance between pulley and wall is not one meter. It has changed by 1 meter. If it was 10 m before, it now is 11 m.
  • #84
2 meter?
  • #85
Hurray ! (but: why the ? question mark?)
So, to summarize the last umpteen posts: when the cart moves 1 thing, the block moves 2 things (meters, inches, millimeters, whatever distance).
Now, next step: if the cart is accelerated by 3 m/s2, what must be the acceleration of the block ?
Likes gracy
  • #86
gracy said:
2 meter?
Hooray!
So for each metre the car moves, the block moves 2 m.
If the car's acceleration is a, what is the block's acceleration?
Likes gracy
  • #87
Likes gracy
  • #88
acceleration of the block =2 multiplied by trucks acceleration
i.e 6 m/s^2
  • #89
So T-150=30 multiplied by6
T=330 N
  • #90
BvU said:
Bedtime for me
Even I am going to sleep.
  • #91
T=330 N
You got it. Sleep well.
Likes gracy
  • #92
"haruspex" and BVU bigThanks for all your answers .And BVU sorry for that question mark:smile:
  • #93
You both are true homework helper.BVU you used the whiteboard so nicely.Very neat diagram
.Next time when Calculus master will visit physics forum,will get homework done.:smile::smile:
  • #94
dean barry said:
if the acceleration of the block = 2 * truck acceleration, then the force required in the string = m * a
then add the friction force
Really fast service ,I got this after 88 you in 10 th post.
