Friction and Pulleys
  • #76
BvU
2019 Award
13,598
3,285
That is still saying the block moved by 1 meter ([edit] well, not really, but never mind (*) ). Is it also what you mean to say ?
Would it help you if you made a drawing of the intial situation and one of the situation where the flat car has moved over some distance ?
Or perhaps you do a little experiment where you attach a wire to a fixed point (the wall) on one end and to some object (the block) on the other. Let you finger play the role of the pulley and move your finger by 10 cm. How far did the object move ?
(*) you can easily see that can't be right: imagine the car is fifty meters long and moves by 1 m. No way the block is "where the pulley was".
  • #77
2,486
82
It is one metre closer to the pulley
That's why I answered that Distance covered by block would be equal to shorter length of string(the region of string which connects block and pulley).That is block will reach where pulley was.
  • #78
2,486
82
It is one metre closer to the pulley.
How to interpret it.
  • #79
BvU
2019 Award
13,598
3,285
If the pulley moves 1 m away from the wall, it has to reel in the block by 1 m. So the pulley moves 1 m and pulls in the block by 1m. Over what distance has the block moved wrt the wall ?
The length itself of the shorter section has nothing to do with it. It's about how much that length has changed that's relevant.
  • #80
2,486
82
It's about how much that length has changed .
1 meter?
  • #81
2,486
82
So the pulley is one metre further from the wall,
Does that mean distance between wall and pulley is 1 meter?
  • #82
BvU
2019 Award
13,598
3,285
Yes, that length has changed 1 meter: the pulley reeled it in by 1 meter. he pulley itself moved by 1 meter. How much has the block moved wrt the wall ?
Likes gracy
  • #83
BvU
2019 Award
13,598
3,285
No, distance between pulley and wall is not one meter. It has changed by 1 meter. If it was 10 m before, it now is 11 m.
  • #84
2,486
82
2 meter?
  • #85
BvU
2019 Award
13,598
3,285
Hurray ! (but: why the ? question mark?)
So, to summarize the last umpteen posts: when the cart moves 1 thing, the block moves 2 things (meters, inches, millimeters, whatever distance).
Now, next step: if the cart is accelerated by 3 m/s2, what must be the acceleration of the block ?
Likes gracy
  • #86
haruspex
Insights Author
5,993
2 meter?
Hooray!
So for each metre the car moves, the block moves 2 m.
If the car's acceleration is a, what is the block's acceleration?
Likes gracy
  • #87
BvU
2019 Award
13,598
3,285
Likes gracy
  • #88
2,486
82
acceleration of the block =2 multiplied by trucks acceleration
i.e 6 m/s^2
  • #89
2,486
82
So T-150=30 multiplied by6
T=330 N
  • #90
2,486
82
Bedtime for me
Even I am going to sleep.
  • #91
haruspex
Insights Author
5,993
T=330 N
You got it. Sleep well.
Likes gracy
  • #92
2,486
82
"haruspex" and BVU bigThanks for all your answers .And BVU sorry for that question mark:smile:
  • #93
2,486
82
You both are true homework helper.BVU you used the whiteboard so nicely.Very neat diagram
.Next time when Calculus master will visit physics forum,will get homework done.:smile::smile:
  • #94
2,486
82
if the acceleration of the block = 2 * truck acceleration, then the force required in the string = m * a
then add the friction force
Really fast service ,I got this after 88 you in 10 th post.
Related Threads on Friction and Pulleys
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
