Friction and tension problem
  • Thread starter Sagekilla
Find the the acceleration, a[/i, and the Tension, T, in the system shown below if (a) m1 = 5 kg and (b) m1 = 2 kg. assume the coefficient of kinetic fricton on the incline plane is µk = 0.1.
Other relevant information:
Mass 1 is a 5 or 2 kg block on a 30 degree incline plane (based so that Fy is Fsin(30) ) connected to a massless rope that holds Mass 2, a 5 kg block, over a pulley.
Ff = (µk)(Fn)
w = mg (acceleration due to gravity is assumed to be 10 m/s^2 for easy calculation according to the professor)
Fnet = ma
I solved for the weight of mass 1 as being:
m1 = 5 kg: W = 50 N * sin(30) = 25 N
m2 = 2 kg: W = 20 N * sin(30) = 10 N
And found force of friction:
Ff = 0.1 * 25 N = 2.5 N
The weight of block m2:
w = 10 m/s^2 * 5 kg = 50 N
I tried creating a FBD for block m1, where the following forces were applied:
W = 25 N
Fn = 25 N
Ff = 2.5 N
F = Wm2 (Wm2 = 50 N)
And a FBD for block m2, where:
W = 50 N
Except, I'm confused where to go from here now. I know I have to calculate tension still. I'm thinking that the total force being applied on m1 according to Newton's 2nd Law is:
Fnet = ma - Ff = 50 N - 2.5 N = 47.5 N
And acceleration is: a = 47.5 N / 5 kg = 9.5 m/s^2
2nd attempt:
I know Fnet = ma - T. and Fnet is not 0 N, it's 50 N. Since the rope is massless the tension is 2T = 100 N.
I therefore arrive at the following answers of:
a = 9.5 m/s^2
T = 100 N
Does this look right?
Answers and Replies
Redbelly98
Staff Emeritus
Insights Author
12,134
161
Welcome to PF, Sagekilla.
Mass 1 is a 5 or 2 kg block on a degree incline plane (based so that Fy is Fsin(30) ) ...
Do you mean the block is 30 degrees from the vertical direction?
... connected to a massless rope that holds Mass 2, a 5 kg block, over a pulley.
Ff = (µk)(Fn)
Fnet = ma
I see some issues here, mainly with terminology.
How about calling these mA and mB instead, since you say earlier that Mass 2 is fixed at 5 kg. It would make sense then to let m2 be the mass of Mass 2.
Also, the weight is simply m times g. It looks like you're calculating the weight force's y-component (because of the trig terms). Is this supposed to be the normal force--I see you use these numbers for calculating friction force next?
True if 25 N is the normal force, which is true if 30 degrees is with respect to vertical.
Okay, so now m2 is for Mass 2?
W = 25 N
Fn = 25 N
Ff = 2.5 N
Again:
W = m1 g = ____?
Fn -- looks okay.
Ff -- looks okay.
F (rope tension?) is not necessarily the weight of Mass 2, since there is an acceleration.
W = 50 N
The rope tension should appear here too.
Not quite.
Fnet = ma, period
I'm gonna stop here for now, and give you a chance to work through these comments before going further.
2nd attempt:
a = 9.5 m/s^2
T = 100 N
Thanks for your help :)
Here's the exact diagram if it'll help you any
http://img100.imageshack.us/img100/3443/diagramzv7.png [Broken]
I'll read over your comments and rework the problem once more and reply once I've finished.
I did the problem once more, this time only trying to solve for (a) to make things less confusing:
I found the Force in the x direction for mass 1:
F = 5 kg * 10 m/s^2 * cos(30) = 43.3 N
I solved for weight of mass m1:
w1 = 5 kg * 10 m/s^2 * sin(30) = 25 N
The normal force is the same magnitude as the weight for mass m1:
Fn = w1 = 25 N
And solved for the Frictional force, Ff, with coefficient of friction 0.1:
I also solved for weight of mass m2:
w2 = 5 kg * 10 m/s^2 = 50 N
The FBD for m1 was this:
w = -25 N
Fn = 25 N
Ff = -2.5 N
F = -43.3 N
T = ?
The FBD for m2 looks like this:
w = -50 N
T = ?
Redbelly98
Staff Emeritus
Insights Author
12,134
161
Thanks, yes, that is helpful.
Not sure what you mean by "the Force in the x direction". There are several forces on m1 that act in the x-direction. Do you mean the sum of all the forces along x? Or something else?
Also, can you confirm that the x direction is the same as the vector a that is drawn in the figure, i.e. along the sloped surface?
The weight of anything is it's mass, multiplied by g=10m/s2. So the weight of mass m1 is m1*g. No trig is involved with finding the weight.
Fn = w1 = 25 N
Uh, the normal force is different than the weight because of the slope. You will need trig for that; it equals the weight only when the angle is zero degrees.
Related Threads on Friction and tension problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
