Friction and toboggans
  • Thread starter STEMucator
STEMucator
2,075
140
A 15kg toboggan is pulled across the snow at a constant speed by a horizontal force of 22N.
a) What is the force of gravity on the toboggan?
b) What is ##μ_k##?
c) How much more force is needed to pull the toboggan if 105kg is added to the toboggan?
##m = 15kg##
##a = 9.8 m/s^2##
##F_A = 22N## [Applied force]
##F_N## [Force normal]
##F_K## [Kinetic force/Friction]
a) ##F_G = ma = (15 kg)(9.8 m/s^2) = 147N##
b) The toboggan travels at a constant velocity ( a = 0 ) with no ups and downs. This implies that ##F_N = F_G = 147N## and ##F_K = F_A = 22N##
Now ##F_K = μ_KF_N \Rightarrow μ_K = \frac{F_K}{F_N}##
So that ##μ_K = \frac{22N}{147N} = 0.15##.
c) Hm so the total weight of the toboggan will now be ##m = 120kg## and we have the kinetic friction coefficient ##μ_K = 0.15##.
Would it just be :
##F_K = μ_Kma = (0.15)(120 kg)(9.8 m/s^2) = 176.4N##
So we would require 176.4N+22N = 198.4N more to keep the toboggan at a constant velocity. Is this okay?
Answers and Replies
PeterO
2,426
48
b) What is ##μ_k##?
##m = 15kg##
##a = 9.8 m/s^2##
Would it just be :
Are you sure you should add 22N at the end.
Have you calculated the force needed for the loaded toboggan, or the the extra force needed for the load?
41
I think PeterO says it all
STEMucator
2,075
140
You're right. My first instinct was 176.4N was the answer. Then I second guessed myself for a moment.
So we would need 176.4N to pull to toboggan.
41
Be careful of the question. It asks for how much MORE force is needed, not how much force is needed.
STEMucator
2,075
140
Then I would need 176.4N - 22N = 154.4N MORE force to pull the toboggan.
176.4N Is the force needed to pull the toboggan while 154.4N is how much more force I need to move the toboggan as compared to when the toboggan didn't have as much mass ( It only required 22N ).
haruspex
Insights Author
2020 Award
36,206
6,823
You seem to have introduced an error of 0.4N. 105kg is exactly 7 times 15kg, so the extra force should be exactly 7 times 22N.
Related Threads on Friction and toboggans
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
