Friction and weight
  1. Apr 10, 2007 #1
    A lightweight rope is wrapped around a 100lb drum, passes over a frictionless pulley, and is attached to weight, W. The coefficient of friction is 0.50. Determine the maximum amount of weight that can be supported by this arrangement.
    I've drawn a picture, showing what I think are the forces on everything.
    I need help solving this, as I'm not sure how to actually do it. The answer, I have(given to me) is W=75lbs.
    2. Relevant equations
    3. The attempt at a solution
    Forces in x direction = 0 = Fa - Nb + Tw
    Forces in y direction = 0 = Na + Fb - 100
    Not sure if there is a moment(and if so, where do I take it about).....also, if not.....I'm not sure how to solve this next.
    Thank you,
  3. Apr 10, 2007 #2
    Doc Al
    Staff: Mentor
    Why not take moments about the center of the drum? Hint: If the drum is just about to turn, what can you say about the friction forces?
  4. Apr 10, 2007 #3
    You have 5 unknowns Fa Na Fb Nb and Tw so you need 5 equations.
    You have 2 equations already.
    When the drum starts to rotate, Coulombs law of friction says
    Fa = mu.Na and Fb = mu.Nb That makes 4 equations.
    You can get a 5th equation by taking moments. If doesn't matter where you take moments about. Choose a point which several forces pass through, so they have zero moment and you get a simpler equation.
  5. Apr 10, 2007 #4
    Ok......so now, I took the moment about the center.
    M = 0 = Fb(d/2) + Fa(d/2) - Tw(d)
    And the 2 equations above. I'm totally lost as to how I mathematically solve these though, or where I start. Also, I don't know the diameter(d)....so not sure how the moment equation will help.....
  6. Apr 10, 2007 #5
    Doc Al
    Staff: Mentor
    Why is one force times d while others are times d/2?
    The d drops out, so you don't need the actual value.
    If you answer my question/hint about friction, you'll be able to rewrite Fb and Fa in terms of Nb and Na. (Similar to what AlephZero told you to do.) Then you'll have 3 equations and 3 unknowns--solve!
  7. Apr 10, 2007 #6
    Ok......I was saying it was the diameter/2.....or the radius. I don't know what I was thinking....I found that mistake, and will try to solve it now....see if I can do it....not sure.
  8. Apr 10, 2007 #7
    yes, I did solve it(it feels good....haha). Thank you for all of your help, I sure appreciate it!!!
