Homework Help: Friction: Blocks and Plane
  1. Oct 2, 2009 #1
    Masses m1 and m2 are attached via a light string and pulley on an inclined plane as shown above. m1 has a value of 12 kg and moves down the plane at a constant velocity of 0.9 m/sec. The plane is tilted upwards at an angle of Θ = 26 °. The coefficient of static friction between m1 and the plane is μs = 0.24 and the coefficient of kinetic friction is μk = 0.19.
    https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/DuPage/phys2111/fall/homework/Ch-06-Forces/friction_block_plane/plane_blocks.gif [Broken]
    What is the mass of m2?
    2. Relevant equations
    F = ma
    f = uk(m1)g
    3. The attempt at a solution
    y1: m1sin(theta) - T - f = m1a
    x1: N - mgcos(theta) = m1a
    y2: T -m2g = m2a
    Plugging in the numbers in to y1 and then I set it equal to T. I then put that equation into y2 and I got 8.5kg for m2, and apparently this is incorrect. Any ideas?
    Is my free body diagram correct? Thanks!
  3. Oct 2, 2009 #2
    kuruman
    You forgot the "g" in m1sin(theta)
    The acceleration in a direction perpendicular to the plane is zero because, as it moves, the block does not jump off or sink into the plane. Use the correct N to find the force of friction f.
    This is OK.
  4. Oct 2, 2009 #3
    Delphi51
    Missing a factor of g in the first term. And of course a=0 so the right side is zero.
Loading...
