Homework Help: Friction/heat calculation
  1. Jan 20, 2014 #1
    I need to find out how much heat is generated by a brake.
    I know heat generated = friction
    The parameters that will affect it friction are
    Normal load (I can choose depending on outcome)
    Coefficient of friction (assumed 0.8 between carbon fiber and steel plate)
    Area of contact (I can choose depending on outcome)
    2. Relevant equations
    I couldn't find relevant equations, which is why i need help in connecting the parameters
    Friction = normal load x coefficient of friction ?
  3. Jan 20, 2014 #2
    Frictional force = normal load X coefficient of friction
    Work = force X distance
    Area of contact is not relevant
    BTW: I'm guessing that it you took separated your work from the "problem statement" (per the homework form), you would have gotten more responses.
  4. Jan 21, 2014 #3
    Thanks, so is the distance angular velocity x time?
    Also, surely the force has to be subject to the coefficient of friction?..
  5. Jan 21, 2014 #4
    The coefficient is part of the computation. You need it to compute the force.
    Assuming a drum brake, distance is radius X angular velocity X time.
Have something to add?
Draft saved Draft deleted
