Solving Friction Problems: Calculating Distance and Time
In summary, the friction force of a conveyor belt can actually speed up a box placed on it, until the box reaches the same speed as the belt. To find the distance the box moves before reaching this speed, energy arguments can be used. The time it takes for the box to reach its final speed can be found using the equation t = v/(μ*g), where μ is the coefficient of friction and g is the acceleration due to gravity.
fball558
147
Friction help!
It is sometimes claimed that friction forces always slow an object down, but this is not true. If you place a box of mass M on a moving horizontal conveyor belt, the friction force of the belt acting on the bottom of the box speeds up the box. At first there is some slipping, until the speed of the box catches up to the speed v of the belt. The coefficient of friction (greek letter mu "looks like a u") between box and belt is . Do not worry about italics. For example, if a variable g is used in the question, just type g and for (u) use mu.
I have 2 questions that do not have numbers, just have to solve for an equation.
(a) What is the distance d (relative to the floor) that the box moves before reaching the final speed v? (Use energy arguments to find this answer.)
(b) How much time does it take for the box to reach its final speed?
The attempt at a solution
not sure how to start. i figured conservation of energy. also the block will experience -mg force, it will have normal force cancelling it out. so then only force is friction force due to belt. this is where i get stuck. also not sure if i have to factor in change of thermal energy or not. anything with friction with have change in thermal.
any help would be great
thanks
Until it comes to rest on the moving surface there is a force acting on M that is equal to the force of friction.
F = μ*M*g
This force will accelerate M until it is going at the speed of the belt.
Since F = m*a
then you can figure how fast it accelerates. Armed with acceleration you can write an equation from kinematics that relates this acceleration and the velocity of the belt to distance. Likewise the time based on velocity and acceleration.
ok since F= u*M*g and F = m*a i can set them equal
m*a = u*M*g i solved for a by dividing by m and get
a = (u*M*g)/m would the (m) cancel? ther is a big M and a small m not sure
then if this is a F = m*a
so F = m*((u*M*g)/m)
am i right so far? i feel like i messed up somewhere
Sorry, of course the m's cancel.
But what you are really interested in is a, isn't it?
That way you can relate a, v, and x.
And you can relate a, v and t.
how are these related? i know if your integrate acceleration you get velocity. that is back to calc 1 stuff. but don't think that works for physics and i don't know where the x comes into play.
These are kinematic relationships. But never mind that. Do it as they suggest.
What will the increase in kinetic energy be?
And you have the force ... so how much work is done on getting the block to speed?
W = F * d
kinetic energy is = 1/2mv^2
delta(E) = w+q i said q is 0
so delta(E) = w delta(E)= KE (1/2mv^2)
w=f*d so
1/2mv^2 = (m(u*g)) * d
solve for d i get
d= v^2/2g
where did i go wrong? this is the wrong answer
w=f*d so
solve for d i get
d= v^2/2g
Well you have it, but you dropped a constant looks like.
1/2*m*V2 = μ*m*g * d
d = V2/(2*μ*g)
yeah realized that
i got the answers now
thanks for all the help
how did you get the time?
Can't you get it from distance and acceleration?
yes that is what i did messed with some of the letters.
eventually simplified down to
t= v/(mu*g) where mu is just u not mass * u
i tried:
d/sqrt(2*d*mu*g)
...it was wrong
jchojnac said:
i tried:
d/sqrt(2*d*mu*g)
...it was wrong
That's because your acceleration is μ*g
V is a constant and is already given. So to find time
V = a*t = μ*g*t
t = v/(μ*g)
thx a lot for u guys helping
Now I get the answer
What is friction?
Friction is a force that resists the motion of objects when they come into contact with one another. It is caused by the roughness of surfaces and can affect the speed and direction of movement.
How do you calculate friction?
To calculate friction, you need to know the coefficient of friction and the normal force. The coefficient of friction is a measure of how rough or smooth two surfaces are in contact. The normal force is the perpendicular force exerted by one surface on another. Multiply the coefficient of friction by the normal force to calculate the frictional force.
How does friction affect distance and time?
Friction can affect distance and time by slowing down the speed of an object in motion. This means that it will take longer for the object to cover a certain distance due to the resistance caused by friction. Additionally, friction can also cause an object to travel a shorter distance than it would without friction.
How can you reduce friction?
Friction can be reduced by using lubricants, such as oil or grease, between surfaces in contact. This creates a layer that reduces the roughness and allows for smoother movement. Additionally, using smoother surfaces or reducing the weight of an object can also reduce friction.
What are some real-life applications of friction calculations?
Friction calculations are used in various fields, such as engineering, physics, and sports. In engineering, friction calculations are important for designing machines and structures that can withstand the effects of friction. In sports, understanding friction can help improve performance, such as reducing friction on a bicycle to increase speed. Friction calculations are also used in the automotive industry for designing tires and brakes that can provide optimal grip on different surfaces.
