Friction, Newton's Laws
The two blocks shown in the diagram are at rest on a horizontal surface when a force P is applied to block B. Blaocks A and B have masses 20kg and 35kg respectively. The coefficient of friction between the two blocks is 0.35 and between the horizontal surface and Block B is 0.3.
Determine the maximum force, P, before A slips on B.
F = ma , Friction max = uR
Okay this thing has been killing me for months.
Friction between B and the ground is (20 + 35)g(0.3) = 16.5g and between B and A is
(0.3)(35)g = 10.5g. This produces anti-friction which propells A forward. Friction between A and B is (20)(0.3)g = 6g.
So, P should equal 16.5g +10.5g + (10.5g - 6g) = 31.5g N.
I'm supposed to be getting 35.75g N.
Where am I going wrong?
Answers and Replies
Doc Al
Mentor
45,140
1,443
:bugeye: Anti-friction??? The only force propelling A forward is the friction from B.
Hint: When the static friction between A and B is at its maximum value, what is the acceleration?
Sorry, that's what I mean.
The acceleration of A or B?
The acceleration of A relative to B will be 0 if slipping doesn't occur.
Doc Al
Mentor
45,140
1,443
Consider A first. What's the acceleration of A when slipping is just about to occur?
Exactly! :wink:
Well if the force pushing A forward is (10.5)g, the acceleration should be (10.5)g/20, =
(0.525)g m/s^2.
Doc Al
Mentor
45,140
1,443
What's the maximum static friction force acting on A?
The normal reaction by the Coefficient of Friction. (20g)(0.3) = 6g N.
Doc Al
Mentor
45,140
1,443
Good! Except that here μ = 0.35.
Okay, I did it again, and got the right answer.
So let me see if I've understood.
I've included a force diagram.
The frictional forces acting on B are [(55g)(0.3) + (35)(0.35)] = 28.75g N
The force pushing A forward is (20g)(0.35) = 7g N.
To make B move, P must be 28.75g, and to ensure that there is no relative acceleration between A and B it must be (28.75g + 7g) = 35.75g N.
Doc Al
Mentor
45,140
1,443
The friction force of A on B is equal and opposite to the friction force of B on A (which you have calculated correctly).
Good. So what must be the acceleration of A?
If the friction force on B is the coefficient of friction by the normal reaction, should it not be
(0.35)(20g)?
F = ma, ma = 7g, so a = 7g/20 = 0.35g m/s^2.
Doc Al
Mentor
45,140
1,443
(0.35)(20g)?
Exactly.
Good! So what must be the acceleration of both A and B at that point? What force P is required to produce such an acceleration?
If the acceleration of A is 0.35g, the acceleration of B must also be 0.35g, so that there is no relative acceleration between them and slipping will not occur.
F = ma, so P = (35)(0.35g).
Evidently I've gone wrong somewhere. Haha.
Doc Al
Mentor
45,140
1,443
Good!
P is not the only force acting on B.
Hint: Try treating both blocks as a single object.
P minus the two frictional forces acting on B has to produce an acceleration of 0.35g.
So [P - 16.5g-7g = 35(0.35g)]
P = 35.75g N
And if both blocks were a single object, the 7g N forces would not affect the system, and the mass of the system would be 55kg.
So [P -16.5g = 55(0.35g)]
P = 35.75g N
Doc Al
Mentor
45,140
1,443
There you go. :approve:
Thank you very much for your help. :smile:
Related Threads on Friction, Newton's Laws
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
